sometimes our mk2 1.4 ZR wont start, turns over fine but doesnt fire, if I apply Wide Open Throttle it will, it might splutter for a second but then its all ok. [its not coolant or HG related, its just been done]
fuel pump primes - but not every time
I have tried FP relay, swapped for a known good one, and also a bridged one [FP runs all the time], cant really say for sure if it made a difference due to the fact that once it has started, switching off and trying again it starts fine
mostly does it when cold, or when stood for a few hours
fuel pump is noisy, compared to a mk1 ZR we also own
new fuel filter put in yesterday
otherwise when it is running, its running sweet, really strong, good on fuel, doesnt miss or owt, theres no fault codes showing with my scanner.
has anyone got any advice on what I could check - please bear in mind the above that it starts if Wide Open Throttle is applied until it goes, and its only occasional.
thanks
thanks
