sb
Mar 15, 2015 23:21:31 GMT
I need to build cross section B:B Can anyone recommend where can supply rubber I can cut myself to size? The lower part is approx. 1" and the upper 1/2"
Hockey puck's could be machined down on lathe to the spec you require. They are pretty hard though and not soft like the original rubber items. What about Range Rover Classic body mounts -
Mar 16, 2015 10:09:48 GMT
Companies like powerflex sell universal top-hat bushes. It's pretty likely they'll have the size you want or something pretty similar that you could take to an engineering shop and have turned down to the right size on a lathe.
Mar 16, 2015 19:47:18 GMT
You can buy the bar from super-flex to make your own (or probably ebay much cheaper) They even tell you the cutting speeds on their website so its super easy! www.superflex.co.uk/fitting3.phpJames
Too many projects, not enough time.
