mclellanmac
Hand me the hammer and the WD40
Mar 25, 2015 20:06:27 GMT
Hi there guys,
I've got a 1992 Mercedes 190 1.8, and to be honest it's a total curse word to start from cold!
Once it's warm, or even just been started once it will start fine, that first time though, it takes ages, it just spins for a while, then starts coughing, back fires a bit and the finally catches, after 5 or 6 turns of the key.
If anyone has got any ideas of where to start it would be much appreciated, as it is damn annoying of a morning!
Mercedes 190e, Lovely
MK4 Golf GTi 20v Turbo, Dull, but always works!
hario
S202 C300STD
Apr 15, 2015 11:23:36 GMT
Its probably the big curse word IACV valve that looks like an aux water pump.
Try taking it appart and WD-40-ing before replacement.
Apr 15, 2015 11:28:17 GMT
they have a relay behind the battery. OVP relay, without this non of the cold start systems work. Can be cured sometimes by pulling and replacing.
'98 e36 316i lux '97 mx5 harvard '87 Saab 900 T16s
mclellanmac
Apr 17, 2015 12:41:27 GMT
Thanks for the advice I shall have a look, its becoming a real pain!
tdipd
Remove and clean the ICV (i have a spare from a 2.0L i may sell if it doesnt fit my 16v)
And,remove the OVP relay, pry open the aluminium casing, and resolder the joints as the solder cracks over time. Doing this solved my cold start issues. Theres a guide on mercedes-190.co.uk I think.
mclellanmac
Apr 20, 2015 15:27:29 GMT
The cleaning of the ICV sounds straight forward enough,
this soldering business however......i shall have to have a word with one of the Lecky lads at work, although i think anything more complex than a continuity check is beyond most of them.
tdipd
Apr 20, 2015 20:42:47 GMT
The cleaning of the ICV sounds straight forward enough, this soldering business however......i shall have to have a word with one of the Lecky lads at work, although i think anything more complex than a continuity check is beyond most of them. the solder develops whats known as a 'dry joint' over time. The solder is already present, it just has a crack in it. All you have to do is pry the aluminium cover apart from the bottom, and heat up each pool of solder until its molten, then remove the iron so it can set again. Its pretty easy
mclellanmac
The cleaning of the ICV sounds straight forward enough, this soldering business however......i shall have to have a word with one of the Lecky lads at work, although i think anything more complex than a continuity check is beyond most of them. the solder develops whats known as a 'dry joint' over time. The solder is already present, it just has a crack in it. All you have to do is pry the aluminium cover apart from the bottom, and heat up each pool of solder until its molten, then remove the iron so it can set again. Its pretty easy Ahh that doesnt sound to difficult to be honest, i shall have a crack, I will take it apart and have a look, I have access to all the tools so shouldnt be to difficult.
