Found this and thought it may be of use to someone, all are 1/8 NPT fitting (pretty common especially on Fords). Very handy if you're changing engines and want to match to your existing gauges.
Black (screw fitting) - 52610
@25° = 195 Ohms
@100° = 20 Ohms
White (screw fitting) – 52750 – listed for a Escort TC, Mk.2 Cortina TC.
@25° = 250 Ohms
@100° = 22 Ohms
Reads too high. Normal running is bottom of the red. Into the red when the engine gets hot.
Green (spade fitting) – 52700 - listed for a Morris Minor, Vitesse, Herald, Magnette, Austin A30, A40, Husky etc.
@25° = 300 Ohms
@100° = 14 Ohms
Doesn't fit, has the larger 5/8” thread size.
Black (screw fitting) - 53170
@25° = 358 Ohms
@100° = 55 Ohms
Normal running it sits bang-on half way. At the point the fan kicks in it’s only one letter higher on the gauge.
Red (spade fitting) – 52710 - early Anglia
@25° = 650 Ohms
@100° = 43 Ohms
Doesn't fit, has the large 5/8” thread size.
Black (spade fitting) –52630 - late Anglia
@25° = 662 Ohms
@100° = 58 Ohms
Reads too low. Normal running is on A. Will rise up the gauge when it gets hot. Fan kicks in on M.
Intermotor sender part numbers and specs
Yellow (screw fitting) - 52620
@25° = 775 Ohms
@100° = 23 Ohms
52910
@25° = 780 Ohms
@100° = 37 Ohms
White (spade fitting) - 52740
@25° = 1005 Ohms
@100° = 64 Ohms
Voilet (spade fitting) - 52600
@25° = 2000 Ohms
@100° = 41 Ohms
Violet (screw fitting, supersedes red screw fitting) - 52640
@25° = not available
@100° = 51 Ohms
@25° = 195 Ohms
@100° = 20 Ohms
@25° = 250 Ohms
@100° = 22 Ohms
@25° = 300 Ohms
@100° = 14 Ohms
@25° = 358 Ohms
@100° = 55 Ohms
@25° = 650 Ohms
@100° = 43 Ohms
@25° = 662 Ohms
@100° = 58 Ohms
@25° = 775 Ohms
@100° = 23 Ohms
52910
@25° = 780 Ohms
@100° = 37 Ohms
@25° = 1005 Ohms
@100° = 64 Ohms
@25° = 2000 Ohms
@100° = 41 Ohms
@100° = 51 Ohms
