kel
Kieran
Are the spouts the drain ports on the bottom of the float chamber or from the over flows?
You need to replicate the angle the carbs were mounted on the bike, otherwise the floats will not shut before they flood.
The Ashby Jackson fleet:-
1979 Mini Clubman 1.8 K series 1978 Skoda 110r Project 130RS K-oupe 1978 Austin Allegro 1500 SDL Estate 1984 BMW K100 Sidecar outfit 1999 Yamaha FZS 1000 Fazer 1991 Kawasaki ZXR400 race bike 2002 Kawasaki ZX9r race bike
kel
From what i have been reading the angle does not need to be the same. But yeah i agree it would be ideal if i could replicate it but on the bike they were almost virtical. Rubbish generic pic but heres where they leak from:
I'm interested in the out come of this as my mate has a similar issue with his carbs, my first thought was it could be a return to the tank but tbh weve not looked at it recently
Sent from my GT-I9505 using proboards
Kieran
They're the float bowl drains.
The screw in the side is a taper seat, so either they sent seated correctly or you are over pressurising them.
kel
The drains where loose, my error!
Anyways now they are leaking from other places. Maybe these cbr600 F2 carbs are not to be used with a bike fuel pump.
Kieran
If they leak then the floats are not closing.
Either stuck float / too high fuel pressure or Wrong mounting angle - fuel level is reaching the overflows before float valve closes. Adjust the float height or reset angle.
shin2chin
My carbs leaked when I first plumbed them in. Float needle valves get stuck and you get leaks out of the vents at the top. A good clean and blow out with compressed air helps them seal better, set your float heights whilst your at it.
kel
Fixed now guys, floats where sticking on two carbs.
Ive also fixed the non cranking issue it was the switch on the old auto shifter. I had it removed as ive converted to manual.
