What can i do to the lucas pump on the 1800 td lump that comes in the sierra/escort? Its a 90 spec engine with a boost compensator.
I'm going to stick a much bigger turbo, t3 or td04/5 with much more boost (25-30psi) its also going to have a big front mount intercooler to keep the temps down and thinking of making a custom freer flowing inlet.
Ive seen you can get 12mm rotor head from iveco dailys or something, is this the way to go for more fuel?
Nobody dies a virgin, because lifes curse word us ALL
Apr 11, 2015 16:17:37 GMT
www.fordwiki.co.uk/index.php?title=Fuel_and_Boost_-_1.8TDThere ya go, I tuned my mk5 td escort van this way, ran about 18psi, turned the fueling up loads made a stealth cone air cleaner, egr deleted, single small capacity exhaust center box and a straight through rear pipe, cleaned out the inlet manifold etc, it went very very well!! You ideas of a larger turbo are a bit ott if I'm honest, it'll be laggy as hell, I kept with a standard size turbo, but a nice turbo technics fully rebuilt one.. I've still a few bits and pieces from that motor if you're interested
1970 Beetle 1600
1973 Rover P6 2000SC
1993 Audi 80 Avant 1.9TDI
1996 Transit SWB pop top camper, 2L Twink
Apr 12, 2015 21:06:36 GMT
ive done the pump mods already, i was just wondering if u can change the head of the pump etc to a bigger head?
even with a hybrid turbo?
ill go with the pump tweeked, the boost is turnt up 3 turns on the actuator.
its going in my mk5 cortina estate whenever i get round to it
what bits do u have? pm me
