Apr 11, 2015 20:45:04 GMT
Hello to all those in the know. I would like some advice on fitting the edis system before I jump on in. Could someone tell me if its possible to fit the edis system to the rover kv6 engine. I'm planning on fitting one of these lumps into a 70s project I have kicking around and was hoping to use this aftermarket system for the ignition as I don't have the fobs and ecu from the donor car. Cheers in advance for any advice and if the answer is favourable I hope to post a new thread asap.
Kieran
Apr 11, 2015 21:06:28 GMT
You will need something like megasquirt in conjunction with the Edis.
The edis unit is just an ignition module with fixed spark timing. It needs a megajolt to give you ignition advance, but you need something to drive the injectors too unless you converting to carb, hence the need for megasquirt.
The Ashby Jackson fleet:-
1979 Mini Clubman 1.8 K series 1978 Skoda 110r Project 130RS K-oupe 1978 Austin Allegro 1500 SDL Estate 1984 BMW K100 Sidecar outfit 1999 Yamaha FZS 1000 Fazer 1991 Kawasaki ZXR400 race bike 2002 Kawasaki ZX9r race bike
Hi cheers for that. Yeah I was hoping to convert to carbs, maybe bike carbs. Not sure yet tho. Thanks for the help.
cheapest simplest and most efficient route to get it running I think is to get an Emerald ecu and a plug n play patch loom for the standard engine loom.
not 100% if emerald do this off the shelf, but they have done for the 4 cylinder k"s for years.
reason I say cheapest is you don't need to buy three carbs and a manifold, any trigger wheels or extra parts, all the original kv bits should be configurable to the ecu, will use lots less fuel, more reliable.
Last Edit: Apr 12, 2015 7:59:50 GMT by welshpug
