Is this stuff all created equal? I've got a stainless exhaust which rattles where two pipes cross over each other so (in textbook 'bodge' style) I bought some eBay heat wrap to prevent it.
Lasted for about a week before turning to dust! Stuff was rated (apparently) to 1022 degrees, any other stuff higher? Seen some titanium wrap on eBay, is it any good?
hario
S202 C300STD
Apr 15, 2015 11:09:42 GMT
Apr 16, 2015 11:06:07 GMT
Reckon that's about the same as I bought - and cooked!
Apr 16, 2015 15:58:53 GMT
Hi, I would be tempted to put a screwdriver or chisel between them and prise them apart a bit more (don't go mad) to stop them making contact.
Colin
Yeah tried that but can't seem to get them to stay apart! Bloody irritating though - if anyone has any other ideas give me a shout. Spoke to an exhaust fabricator and he reckoned he might be able to sort it out but then never bothered getting back to me
Can you not prise them apart and weld a small brace between them to stop them touching?
Hi, yes at first I was going to suggest joining them with the welder. But they obviously move quite a bit and fixing them together might end up breaking them because they can't move.
Colin
Apr 20, 2015 10:52:21 GMT
I wonder whether they might be able to be welded together but exhausts definitely not my thing. Anyone know of a place in High Wycombe where they can weld stainless exhausts? Sounds like that might be the only way to resolve.
tim124
Apr 22, 2015 16:55:29 GMT
You can weld stainless with a MIG using mild steel wire.......
Problem is I can't weld.
tim124
Apr 24, 2015 20:07:42 GMT
Beg borrow or buy a MIG welder, its so easy to weld......... It will be one of the best things you ever do!
