tomw88
Apr 16, 2015 21:59:51 GMT
Here is my 1993 Vauxhall Rascal Camper Conversion, its rather rough around the edges but I intend to restore it and re do the insides etc to make it a day camper/surf van, but firstly on the list is lowering and some wheels, any ideas/suggestions would be most welcome!!! I have seen Mystery Machines Rascal which was how I found this forum!!
Again suggestions etc welcome!!
Last Edit: Apr 16, 2015 22:00:36 GMT by tomw88
Apr 17, 2015 22:47:31 GMT
Great to see one, they're getting rare on the ground now and they're certainly un appreciated, what engine does it have? The same as the the 1litre Suzuki carry, the Suzuki F10A? If it is (and I think it is) it's a great little revvy engine, although I've heard neglected engines can suffer camshaft problems, is it mated to a 4 or 5 speed box?
What are your plans with it? I've always had a soft spot for these wannabe vans,
Edit, I saw you were asking about lowering, I've no idea what suspensions on the front but it's leaf springs on the back so you will need lowering blocks,
Last Edit: Apr 17, 2015 22:51:22 GMT by fuldatramp
tomw88
Apr 19, 2015 17:44:57 GMT
Its the 1.0ltr Suzuki, its a great little thing, lots of fun! I'm more concerned about the front suspension!!
Apr 20, 2015 21:20:34 GMT
What suspension is it on the front? Is it independent? If so I'm sure the springs could be cut, The back should be easy though, have you got a theme in mind for the van? My friends old Suzuki sj (410) had the same engine, it was great little engine that loved to be kept on song,
tomw88
Apr 21, 2015 18:17:20 GMT
It's basically going to be a camper/surf van, I want it to be useable on a daily basis, less bouncy but still return it to stock, I think some cut springs could be the way forward but may need to source some new ones and keep the old...?
