nel5on
West Midlands
You can see from the photo, I keep the cover off, to check for "Black death" issue. It would be nice to start fresh, with all the dirt and oil being from my ownership...so how can I clean the engine? Degreaser and a waterblast?(Not directly onto electrical connection or ECUs of course) I guess it has a engine breather problem, as it seems a bit wet around that...and it is a known fault on the mercs c270. Any hints?
Covin 996.2 Tucson
sparkyt
selling stuff
I used Mr muscle oven cleaner ...just spray in on so the engine is covered in foam . . Leave it for 10 mins and wash it off ....
nel5on
West Midlands
Oven cleaner has sodium hydroxide in it, for those who aren't aware, sodium hydroxide is also called lye. It's a very powerful base (the chemical "opposite" of an acid, if you will) and it eats the hell out of aluminum. I used a kitchen all purpose cleaner, and a tooth brush and a watering can. Post photo tomorrow.
Covin 996.2 Tucson
sparkyt
selling stuff
Works ... well then ....
Truck wash and a jet wash , spray it on and blast it off....squint it smarts a little.
Failing that I use cillitbang spray which when viewed at an obscure angle looks like an incredibly rude word but cuts through grease and road grime in seconds,...
nel5on
West Midlands
May 10, 2015 17:56:51 GMT
Not 100% clean...but now I can see any leaks or problem areas in the future.
Covin 996.2 Tucson
May 10, 2015 19:50:39 GMT
What did you use in the end?
nel5on
West Midlands
May 10, 2015 20:27:03 GMT
Covin 996.2 Tucson
I used a kitchen all purpose cleaner, and a tooth brush and a watering can. What ever works ! Nice engine by the way........
taurus
May 11, 2015 10:31:07 GMT
Re. Mr Muscle - I know a guy who uses it and swears by it. I was worried about it eating aluminium so I tried it on a scrap model glow engine and it didn't damage the alloy.
I also tried another brand of oven cleaner and it ate the aluminium. (Oven Pride I think it was)
So just saying, some oven cleaners seem to be safe to use but some aren't.
I used Mr Muscle to clean out my focus diesel turbo when there variable vanes seized up
Honda Concerto driver
