May 23, 2015 18:29:49 GMT
Hey all,
Not sure if I'll be able to get any help with this but thought I'd see.
I've put a 2.8 power steering rack on my 2 litre pinto capri and need a pump for it.
Instead of trying to source a pinto pump which runs on a belt and changing all the pulleys, I thought I'd just buy an electric pump and wire it straight to the ignition so it will be on when the car is.
Anyway, I've just got a electric pump from a ford c-max thinking I could just wire a live from the ignition and earth it and that would be it, job done.
However, I've gone to test this today by putting wires straight from the battery to the terminals on the pump and got nothing.
I never thought about this when I bought it, but is it not working because it needs the sensors, which would be on the c-max, to tell it to run?
Obviously I'm not gonna be installing any sensors on the capri but if I know that, I can try find another electric pump+reservoir that will run with just a live and earth.
Thanks for any help, Paul
May 23, 2015 19:18:13 GMT
I've never had a problem with the weight of the steering on a Capri even with wide wheels but Why not put the original rack back on and modify a corsa eps to fit it's in the steering column and is a tried and tested route with escort mk1 and 2, mantas, and lots of other non power steering applications. There will be lots of info on the net for fitting etc
Failing that go to the gym
Last Edit: May 23, 2015 19:19:50 GMT by fordperv
93fxdl
Enter your message here...
May 23, 2015 19:58:48 GMT
froggy
May 23, 2015 20:21:13 GMT
The feed will be permanent it needs a speed signal to work but you'll have to figure out which wire is which . It will also need a switched live from the ignition . I haven't looked at one closely but most likely two connectors on the pump with a little Ecu to ramp up pressure based on road speed and steering angle . The cheap signal generators for the Mitsubishi corsa epas might do the job or go for an older simpler Saxo or a class pump
May 23, 2015 22:25:46 GMT
I know the motors fitted to Fiat Seicentos have their own ecu in the passenger footwell
May 24, 2015 16:39:19 GMT
Saxo one works with just a live and earth.
May 25, 2015 16:29:32 GMT
Thanks for all the advice, just bought a saxo pump. Wasted money on the c-max one, but hey ho, will teach me to do some research first.
The steering wasn't really a problem to be honest, I just came across a 2.8 rack and crossmember and thought it would be a good thing to have, especially for parking.
May 25, 2015 17:22:41 GMT
I drove a saab 99 with ems quick rack for years, so anything feels pretty light after that. My sierra was manual and was just fine..
'98 e36 316i lux '97 mx5 harvard '87 Saab 900 T16s
May 25, 2015 18:31:50 GMT
It was never a problem, I just like messing about with the car....it is a project after all.
It doesn't help really that it's got wider, lower profile tyres on and a smaller steering wheel.
scimjim
Club RR Member Number: 8
May 31, 2015 20:36:30 GMT
get a much older pump that just has +ve and -ve from a relay. I helped a mate fit one to a hybrid 100" 3.9EFi Series Land Rover from a late 80s J car - toyota or Nissan?
bigdaz
A Vauxhall corsa steering column is what you need, you can buy kits to put them in mk1/mk2 escorts so I'm sure you could get one pre modified for a Capri, the ones I've seen have a knob to adjust so you can make the steering stiffer or lighter, they work really well,
A Vauxhall corsa steering column is what you need, you can buy kits to put them in mk1/mk2 escorts so I'm sure you could get one pre modified for a Capri, the ones I've seen have a knob to adjust so you can make the steering stiffer or lighter, they work really well, I'd go the column route if I hadn't already modified and fitted all the crossmember and rack. I've got a saxo pump now that seems to be working fine so I'm going to get some pipes made up and run that. Thanks for all the help. I know the column route probably would have been easier and potentially cheaper but it's done now. I'll post with an update when I've got the pipes and tested it properly. Thanks again for all the help. Paul
Where do you get the fitting kit for a mk2 escort.? Which year /model corsa do I need to look for, new to this game.!!
Where do you get the fitting kit for a mk2 escort.? Which year /model corsa do I need to look for, new to this game.!! Have a nose at the link above should give you the info you need Control units available cheaply on evilbay
froggy
Hydraulic will feel a lot better than an epas with a dial as the assistance never fully goes off so can feel a bit vague at speed . With a proper speed and rpm signal the assistance is proportional to road speed above 30 mph so it just measures torque input but with a little control dial it doesn't know how fast your going
Mates got a saxo pump in his mk2 escort works a treat..I'm going to go that route with the 385sb in capri
mk2 ford orion mk2 cavalier sri mk3 cavalier sri 95 clio 16v mk3 cavalier gsi ford scorpio mk3 cavalier tdi nissan 200sx (s13) mk3 ford transit mk2 astra gte rep mk3 3.0 v6 cavalier mk3 fiesta van mk3 capri 1.6 mk3 3.0s capri mk2 polo bready 96 bmw 3.2 evo audi 80 tdi landrover 200 tdi mk3 g40 polovan mk1 facelift vauxhall carlton estate ford sierra vw polo 6n
