All parts available
This is an import Eunos, it really only needs the back edge of the cills doing but Ive been given a car and am moving house so its got to go.
Has some trick* bits
Coilovers, no idea what brand, they could be good, they could be ebay specials, we'll err with them being the latter so no one gets ripped off
Roll bar / style bar - This is most certainly a style bar, but, it really does look like a bonnafide roll bar so you get the looks of being safe but the joys of losing your head if you turn it over, all I know is it will be cheaper than a roll bar for you to purchase. Comes with the shelf carpet already cut round the bars.
IGNORE THE PAINT AND STICKERS HERE, IT LOOKS LIKE THE BELOW PICS NOW
MX5PARTS Stainless exhaust
This one:
Clicky
Makes an exhaust type noise louder than the exhaust type noise Mr Mazda intended. Has a decat pipe bolted to it but its handmade, so consider that a freebee, it does make it hella noisy though
It has an engine, it pull like a fecking train, it leaks oil from somewhere mind, maybe the CAS, maybe the sump seal, I don't have a clue
There's a steering wheel, this is maybe a Chinese one, but it allows the vehicle to be oriented around corners
VLSD, locks and makes the car slide
Steering has a HUGE amount of lock, I've yet to check wether this is because of mintfab hubs or the mod done to the rack, i'm pretty sure it'll be the rack as the hubs don't look fresh or owt. But hey, its a bolt in drifty mod
Like I said, there's all the other bits available... Or the whole car to make it easier. I have been using it daily without issue (there's a knocking bush but other than that)
This one:
Clicky
