Hi,
I need some driveshafts redrilled to 4 x 108 from 5 x 108 can anyone recommend a place/person to do this in the South at all please?
Cheers
N
Last Edit: Jun 5, 2015 10:34:58 GMT by nevtiger
Do you mean the hub hub/flange, or the wheel? The actual driveshaft is splined, with a big thread at the end.
bortaf
I think he must meens halfshaft ? that has the hub built in, any decent engeneering shop will be able to redrill but most wont want to weld up the old holes IME, can you weld? makes it easyer and cheaper to get the work done after i find.
R.I.P photobucket
Yes i mean half shaft/drive shaft re-drilling for new wheel studs.
I can weld the holes up easily enough thanks for the tip
