Hello Retro Rides
Please here me out here.
I bought a seat Ibiza a few months back for the front end to swap onto my caddy Van.
Since then I have acquired a VR6 engine to also fit into my caddy van, due to the front ends of the Caddy and Ibiza being the same I am going to trial fit everything in the Ibiza before I give it a go in my caddy, hopefully it will help things progress at a decent rate in the caddy.
This means that I will have a 1.4 MPI engine going, so here is what we have.
1.4 MPI engine from a Seat Ibiza 2001
116k
belt done at 114K.
Not a lot of history
Still starts and runs, can even be driven around the yard.
Runs well and does not over heat, fans kick in as they should.
What is included for free.
Engine and all ancillaries
Gearbox and linkages
Driveshaft
Key
ECU and any looms you may need
Dials
Whatever else you need for the conversion that I don't need. (I need to keep the ARB and engine mounts.)
There is a fault with the gears some where but I think this may be in the selector. It sometimes pops out of 1st and revers, but I think there is a loose heat shield that is causing problems.
Now the price on this is FREE, how ever, to take it you will have to yoink it out yourself.
I am happy to lend you my engine crane, give you as much space and time as you want.
I could remove the engine for you so that you can just come and collect, but for me to do that I would ideally like a token payment, £50 or so.
I am based in Kent, any questions please just drop me a PM.
116k
belt done at 114K.
Driveshaft
Key
Dials
