Sept 14, 2015 18:03:31 GMT
Over the last 2 years I have been building a W124 superturbodiesel. The first year was spent on the engine and transmission alone as I knew what I wanted to do, but did not have a car to put it in!
The main reason it took so long was that I only have a few hrs free each weekend. Anyway, last summer i managed to get hold of a nice 260E and yes, it was obviously a petrol auto.... After alot of mucking about i got the engine and 6 speed transmission completed and put it into the car.
This required the fitting of Custom engine mounts, exhaust system, intake, front IC, prop, g/b mounts, gear linkage, hybrid loom, E500 ARB, brackets everywhere, electric lift pump, KKD manifold, HX40 super, 8.00mm super IP, gauges, oil and PAS coolers, flywheel, clutch, pressure plate as well as welding up a hole in the floor - well it is a 124 after all. Probably missed loads of stuff from the above list.
The car has been running for a few months now and its a proper rocket, still have a few snagging issues to sort inc a lack of speedo and rev counter (i have a plan for these).
Anyway, i thought i would share some of the pictures and experiences with you. Not been on the dyno....... yet.
Sept 14, 2015 18:04:50 GMT
Sept 14, 2015 18:07:45 GMT
Essential when converting a auto to manual... 190 Cossie pedal.
Sept 14, 2015 18:09:31 GMT
ZF Race enginnering/765 PP and custom flywheel. Ballanced the lot too. Works really well :-)
Sept 14, 2015 18:12:33 GMT
Shortened prop, and yes, got that ballanced too! The can has no vibration at all until you get well into three figures. Part of the remit was the car had to be family freindly.
Sept 14, 2015 18:15:48 GMT
Custom gearbox mount in the spray booth (bathroom) and then fitted.
Sept 14, 2015 18:18:58 GMT
benjy_b
Yorkshire and The Humber
Sept 14, 2015 18:29:23 GMT
Excellent! I think we require a video How's the power delivery? I'm wanting to turn one of my C250's into a STD. I fancy around 250bhp at the wheels but with a really smooth, gradual power delivery and not much smoke. I'm thinking 7mm elements and a tweaked OM606 turbo.
2005 Subaru Forester 2.5XT 1999 BMW E36 318i Touring with OM605 Mercedes Engine 1996 Lada Riva with Honda S2000 Engine
Sept 14, 2015 18:31:14 GMT
So i sent the old pump to sweden and it came back looking like this. 8.00mm twin inlet boost alda jobbie. 250cc!!!!!! Nothing primes injection lines like one of these!
Sept 14, 2015 18:36:23 GMT
Excellent! I think we require a video How's the power delivery? I'm wanting to turn one of my C250's into a STD. I fancy around 250bhp at the wheels but with a really smooth, gradual power delivery and not much smoke. I'm thinking 7mm elements and a tweaked OM606 turbo. Power delievery is how ever you want it, put you foot down into to the carpet and its diesel smoke followed by tyre smoke. The great thing about these pumps is that they are easily tunable, so smoke free running is fairly easy. OM605 is easily capable of 250, but you may need a different turbo.
Sept 14, 2015 18:43:29 GMT
nasty smelly car, the previous owner did not like to take a bath.... ......however he did like a genuine MB replacement engine, what an absolute top result - the GP's literally unscrewed out with no resistance!!!!!!!!
Sept 14, 2015 18:49:45 GMT
So many of these little details like this had to make, little leakdown attachment for the fuel returm banjo in this case. I soldered this part up in my clean room (kitchen)...
Sept 14, 2015 19:11:04 GMT
Epic mate, nice to see another member from Norfolk
Sept 14, 2015 19:27:02 GMT
That looks great man! I'd love to bung a turbo diesel in the W124 wagon I've got here. More please!
tdipd
Sept 14, 2015 20:49:26 GMT
This is bang on my sorta car! I have a 190e cosworth, just finishing the bare shell rebuild on it in the next 2 weeks. But I have so much want for a w124 with a meaty pump, turbo, and maybe an AMG kit stuck on too.
Did you use the gearbox from a w203 c220cdi? and sprinter solid flywheel conversion? open diff or asd?
Sept 14, 2015 21:27:02 GMT
clk320 6 speed. Sprinter flywheel machined to accept SRE765 and correct step for custom friction disc. spent ages working out all the dimensions.....
Sept 15, 2015 9:17:11 GMT
Absolute magic! Bookmarked!! PLEASE, instead of being nagged, chuck pics and details at us!
1986 Mercedes 200 (W124) (Standard and daily) 1976 Peugeot 404 1800 Stickshift (Standard - awaiting complete resto, engine done) 1984 Ford Cortina (P100) LDV - Cab and chassis restored, interior and glass not fitted, brand new 3 liter engine (last 110kw Sierra XR6 engine fitted and married to 5 speed Toyota Gearbox), load body needed.
village
Always carries a toolbox. Because Volkswagen.......
Sept 15, 2015 10:01:08 GMT
bookmarked!
looking forwards to more on this one!!
"The White Van is strong with this one...."
Chris "Chesney" Allen 1976-2005 RIP
Sept 15, 2015 17:17:59 GMT
I suppose I should start at the beginning for the engine – the first step on the project was buying this HX40/KKD set up from a chap called Luke. We ended up good friends. You can see from the ‘reference mug’ the thing is MASSIVE. And as it turns out effective too. I remember the conversations with my wife that went something like, 'you have bought a turbo, for an engine you don't have, to fit in a car you don't have that won't fit it in the first place? ...urmmm yes.
Sept 15, 2015 17:35:26 GMT
As these set ups are not exactly new so what i wanted to do was refine it further. Optimisation. So I have concentrated on flow and reliability. Pump, engine and turbo sorted i looked at the induction and the plenum. Needs more volume and that weedy entry hole needs sorting, so i got cutting and shaping and produced a plenum with twice the volume and a 3" inlet. All the pipe work on the inlet side is 3" and as smooth as possible with the min amount of silicone hose.
Bosses welded in for gauge take offs.
Bracket welded on for modified throttle linkage mount too.
