Genuine Garrett GT3582r - 0.82 Turbine housing - Owen Dev 714568-2
Dual Ball bearing, oil and water cooled.
BHP: from 400 to 675 HP
Compressor
Ind Diameter: 61.4
Exd Diameter: 82mm
Turbine
Wheel diameter: 68mm
A/R: 0.82
T3 4 bolt inlet
3" 4 bolt outlet
Both water lines and oil lines included, oil feed is long so will suit many applications 1/8npt male to -4AN female. Block and turbo adapter may be required for oil feed line.
£650 posted. Cheaper if collected from March - Cambridgeshire
Compressor
Ind Diameter: 61.4
Exd Diameter: 82mm
Turbine
A/R: 0.82
T3 4 bolt inlet
3" 4 bolt outlet
