Sept 23, 2015 18:49:38 GMT
There's a couple of spots of oil on my garage floor. I've had a look under the engine and there is lots of grime so can't really tell where it's coming from
Any advice of where to look? What it could be
sowen
Club RR Member Number: 24
Oil leak on my black cabsowen
@sowen
Club Retro Rides Member 24
Sept 23, 2015 19:12:53 GMT
Usually the oil will be coming anywhere or everywhere from the engine, gearbox or axle, and the best way of finding the source of the leak is to clean the engine first.
Sept 23, 2015 19:34:11 GMT
yeah clean it all up mint and watch it like a hawk everyday
Sept 23, 2015 19:57:22 GMT
I'm thinking the sump but I'm not too sure. I was reckless on the way home from work and got it up to 70.
Sept 24, 2015 15:04:42 GMT
Mine would sit at 90 all night with no issues.
Get it down the jetwash with a spray degreaser. Clean it up and drive it home. Have tea. If no signs of leaks take it for a drive to get it nice and hot. Put it back on the drive and wait for the drip. You won't even have to jack it up.
Asking where your oil leak stems from is a bit pointless. You'll just get guesses.
Sept 27, 2015 20:43:34 GMT
Stupid question but the electrics are very exposed along with the other bits of the engine bay. Wont the jet wash ruin the electrics etc etc
Sept 27, 2015 23:47:10 GMT
Hi, as long as you don't squirt the lance into the back of the alternator, all the electrics will bear the spray passing over them.
Colin
Sept 29, 2015 12:32:34 GMT
If you're worried about spraying it, you should be easily able to crawl under there, wipe it clean-ish with a rag and then see the oil leaks.
Sept 29, 2015 13:14:47 GMT
I'll try the crawling option.
93fxdl
Enter your message here...
Sept 29, 2015 16:33:09 GMT
A trick for finding oil leaks, Give it a good wash, let it dry, then dust over with talcum powder, when its running, any leaks will show up as dark stains on the white powder Ttfn Glenn
