Morning all does anyone know the size of the socket to remove the bolts holding the drive shaft to the flange at the gearbox end they are a multi star internal socket head this is on my 2.6 v6 fwd audi coupe 1994 vintage. Did a google search but no definite answer
Last Edit: Oct 5, 2015 6:56:08 GMT by Deleted
I imagine it's the same as an Audi 100 one which I remember buying. If nobody has replied by tonight I'll venture into the garage and find it.
Jaguar S-Type 3.0 SE
As mentioned it'll be an XZN spline, probably M10. I have a bit set like this; images.esellerpro.com/41/I/864/65/33323-mechanics-bit-set-draper.jpgYou may find some more hidden away on the car at some point and the longer bit is sometimes needed to clear the inner cv joint housing. I'm sure a spline bit only set could be found if you don't need more hex and torx bits!
Last Edit: Oct 5, 2015 12:39:34 GMT by gregg106
