Bought a job lot of these recently and there are way more than i could ever need.
So thought the spares may be of interest on here, i have always found them bloody useful when doing panel work.
I have 2 Sets of 10 yellow 1/8" skin pins 2.9mm dia pin, 50mm long. £6 each (175g a set) (ALL SOLD)
I have 2 Sets of 8 blue 5/32" skin pins 3.7mm dia pin, 50mm long. £5 each (180g a set) (ALL SOLD)
I have 8 Sets of 10 red 3/16" skin pins 4.6mm dia pin, 70mm long. for £6 a set (These are heavy at 550g a set) (2 sets SOLD)
All of them are used but fully functional. Some have the rubber tip missing from the threads and a couple have split plastic pieces that sit against the sheet.
None of this affects them working
Prices are plus postage,unless you want to collect from Harrogate, North Yorkshire.
Easiest to work out by total weight, in case you want more than one set.
Up to 500g will go by RoyalMail 2nd class recorded for £3
More than that and its cheaper to use courier at £4 up to 1kg, £5 up to 2kg, and £6.50 from 3Kg to 5Kg, over that its £8
