I was enjoying the car on the day of the Pistonheads Sunday Service! However, the car decided that once again it would not play ball.
On hard left corners it appeared to be throwing oil out of the vent pipe of the oil separator as seen below:
I thought it was the exhaust but a friend in the Audi RS4 said it was underneath the car!
Yup, I may have been the reason for why the session ended! Bloody POS! Both of my French cars behaved better than this on track! To add insult to injury a Westfield that day running a CVH 1.6 had a stockish breather setup but the breather going from the cambelt side of the cam cover to underneath the car with no issues.
The engine bay is spotless, but the underneath of the car was covered in oil, which I promptly cleaned up. According to the dipstick the car lost 1/4 to 1/2 a litre of oil. Not good!
At the moment the vent pipe simply had a breather filter on it but clearly this will not suffice! I was debating plumbing the vent pipe back into the metering head but surely that quantity of oil loss would cause damage elsewhere!
The only thing I can think of it being is an oil surge issue!
In your experience what will stop oil surge on a Ford ZVH engine?
So far it is running the following:
1.8 ZVH
KE-Jetronic
Bailey Dump valve (the pipes were clean when I temporarily removed it to put on a blanking bung).
Oil drain above the sump IIRC
Bailey oil separator (or should I say oil dumper!)
BC5 Gearbox (as a result I think it is using the earlier sump. It is a one piece affair!).
The suspension is modded but nothing major for the car. It's on Leda coilovers, Nankang NS2R track tyres with it being fully polybushed.
I have considered fitting a catch can but losing that much oil within such a short space of time cannot be doing the engine any favours!
Any other suggestions? I have a nasty suspicion it could be the sump or the lack of a windage tray in the sump. Would having ARP bolts affect the latter?
FWIW it has never thrown oil out ever before even on the return journey. I whacked in an empty bottle onto the vent pipe only to see water in it when I got back home despite topping the oil up.
One day this heap of rubbish will behave. At least it is my heap of curse word.
1.8 ZVH
KE-Jetronic
