Hi
Looking for a set of cheap 15" split rims 7" wide to make a set of custom wheels.
Will not be needing the centers as I'm looking to build something custom so design is not important
Would take just a set of barrels if the lips are readily available new.
As long as they are straight as they are going to be completely refurbed
Anything about?
edit: I now have 6 lips x 0.5" wide (30 hole BBS RMs) so all i need now is 4 x barrels.
Need 4 x BBS RS 30 hole. Looking for 15" x 6" wide
thanks
Dean
'The reason i have pulled you over is to say how incredible and absolutely awesome that is'
Mercedes W109, Mercedes W140 S280 SWB & S320 LWB, W201 cosworth kitted, clk230 Kompressor, w109 300sel, Lincoln Continental 1964, BMW E30 Tech II tourer, MK1 Golf Clipper, BMW E31 840ci sport, JAGUAR XJ40 3.6, Kangoo van, Volvo 740GLE estate, Maserati Quattroporte GTS
Oct 19, 2015 21:01:57 GMT
I've got a pair of 15" 30 hole 1/2" genuine BBS lips if they're of any use?
'73 3.0CS '81 Golf Gti 1.6 '83 Golf 20VT '87 M535i '86 Escort RS Turbo
Yea they could be handy as i think i would probably end up going BBS. What sort of price you looking for them?
Oct 20, 2015 22:00:48 GMT
£50 plus postage, been stripped of lacquer and polished, a few marks but had the worst of the kerbing taken off.
Sounds ok to me PM you paypal and a total cost posted and will send payment across
Will do mate, will get a postage quote tonight and grab some pics for you Friday if that's ok?
Just found some Pics Bit of silicone on the back where they were mounted but will come off with a good scrape.
Oct 21, 2015 11:26:37 GMT
They look fine so just need another pair and some barrels and I'm off to the machine shop They will be completely re-polished. I'm in no rush for them at all so don't go out your way. So I'm guessing these are off BBS RMs so with 6" barrels will get me to 6.5 wide which is probably OK to be honest as I'm currently running 6x13
Oct 21, 2015 17:19:52 GMT
Correct mate from RM012s, will get you a postage quote in a bit if that's ok!
Yea its not rush as I'm in Thailand next week on business so was going to ask you to post towards the end of that week at the earliest
bump to the top as i only need barrels now
BT
Oct 29, 2015 10:41:40 GMT
Tried edition 38 forums?
G4vBr
Oct 29, 2015 10:52:07 GMT
Just incase you didn't know, RMs are 2 piece splits so the centre comes as part of the barrel - ie you'd be paying to have that machined out. It might be better to look for RS barrels as they are a 3 piece split.
Hope that helps.
Top tip cheers, was not aware of that.
Will take a look on the edition forum too cheers
