pork
Sept 2, 2016 18:33:45 GMT
Think I've cured the ecu problem, coils don't blow there fuses anymore, fixed fuel rail too
Ran out of time due to work, so can't get to try it out until Tuesday!!![emoji51][emoji51][emoji51]
Sent from my iPhone using Tapatalk
stevietuck
Sept 2, 2016 19:35:35 GMT
Chuck a sicky and get it sorted!!!
pork
Sept 6, 2016 16:46:33 GMT
It's alive!!!
stevietuck
Sept 6, 2016 18:15:08 GMT
Excellent work sir! Your going to have so much fun in this
pork
Sept 6, 2016 18:16:04 GMT
Long way before it drives, at least we know we're going in right direction
pork
Sept 7, 2016 14:45:54 GMT
Running on all 4, that screeching noise is the gasket between the charger and the black throttle mount, need to finish exhaust up to get rid of the other noises
luckygti
I need to try harder!
Sept 7, 2016 19:27:46 GMT
Loving that, and you can't go wrong with a supercharger
pork
Sept 15, 2016 18:49:08 GMT
Got all final pieces for exhaust Battery cables and battery sorted, just need. Drive shafts and we can go for a test drive!!
pork
Sept 22, 2016 13:54:42 GMT
Zorst all welded up Need to figure out wiring for alternator, I know it's a very basic thing I should know, but where do the wires go lol
Sept 22, 2016 14:30:18 GMT
This is cool!! Like micras like minis! Almost tempted to get a mini and put my charade lump in one as chassis has some rust
pork
Been a while!! Started shafts. First one measured and cut ready for welding and sleeving Second shaft........still in place!!! Won't budge at all, bent my ratchet with a 5 foot bar attached and went through a can of gas trying to heat it up. Suggestions? Sent from my iPhone using Tapatalk
impact gun/wrench, or use a breaker bar with pipe sleeved over
Amazed the ratchet bent the internals usually give out first, you might move it with a 3/4 drive set up but firstly I would try to get someone to put as much load as you dare on the bar then hit it with a lump hammer as well, the shock will often break it free, otherwise try and borrow a high torque impact gun.
pork
That's how I bent this.
Jumping on a 5foot bar lol
JoshO
Cant see photos, if its the nut holding it in you could try a half inch electric ratchet gun? should shock it loose?
stevietuck
Hey bud good to see you back at it. Is it the hub nut on the end of d/s that you cant get off? How about a rattle gun? or if you take the wheel off, can you get at the nut to cut it? Cheers steve
Davey
Resident Tyre Nerd.
As has been mentioned, 3/4 socket if you can get it, Big pipe and if it still wont budge can you use the weight of the car against the bar on the floor? That works well with passat hubs.
Have you checked its not left handed thread and your not just tightening it more?
Last Edit: Feb 9, 2017 15:58:40 GMT by Davey
pork
Don't own one. Might see if I can borrow one
Davey
Resident Tyre Nerd.
Don't own one. Might see if I can borrow one See above, if your anywhere near Nottingham feel free to borrow some stuff!
pork
Cheers. I checked, definitely correct thread
