qwerty
Club RR Member Number: 52
Nov 20, 2015 15:02:11 GMT
Looking at building a mega cheap fast road and occasional track car.
Looking at cheap uprated suspension on ebay, there is fixed rate and height suspension kits available for under the £190 mark in varying heights (40, 60 and 70mmm) or fixed rate coilovers for about £240.
Does anyone have opinions on what would be better. I've used cheap ebay coilovers a bunch of times but always for just getting VAG stuff as low as I could and never for something I'm gunna rag about at a semi sensible height.
£50 saving could go into strut braces or a cheap 2nd hand bucket seat.....
Decisions decisions.
Nov 20, 2015 15:50:33 GMT
I've got ta technix on my mk1 mx5 which I've used on track a bunch of times. I think it really depends what you want to get out of the track time. If you are chasing times and looking for ultimate performance then the cheap ones aren't going to do the job, but if you're just going for a good time and aren't too concerned about ultimate performance then they are okay. I've been in and driven similar spec'd cars with more expensive suspension (Gaz, Koni and MeisterR) and the difference is noticeable (even as a passenger). The ride is better and the car more composed towards the limit of grip (corners as well as acceleration and braking). But do they provide more fun? I'd say probably not.
qwerty
Nov 20, 2015 16:47:35 GMT
Low powered fwd hatchback so definitely not chasing times. Just after something cheap and fun. More emphasis on that than outright speed.
93fxdl
Enter your message here...
Nov 20, 2015 18:34:40 GMT
How about, rag it as standard, then chop the springs, next gut the interior finally if you feel it is worth the expense then start the spending. Years ago a magazine did a feature on cheapy track slags, one of which was a metro GTA which gained glory for passing a hot Scooby in the wet. Afaicr the only work done was service items, and possibly upgraded bushes Ttfn Glenn
Last Edit: Nov 20, 2015 18:37:03 GMT by 93fxdl
Nov 20, 2015 19:44:58 GMT
That's a fair point, depends on the condition of the stock suspension though as often it's cheaper to fit cheap coilovers than replace standard stuff.
bortaf
Nov 20, 2015 23:28:47 GMT
I have a few sets of cheap ebay coilovers from golfs in my garage, in the scrap pile, non lasted more than 8 months with constant road use, given the low life expectancy i'd rather go for lowerd springs on standard struts. Unless you want to go uber low or really really need to get the corner wieghts spot on i'd never fit coilovers personly, especialy cheap ebay tat, i'll dig one out and see what make they are so you can avoid them
R.I.P photobucket
qwerty
I've had most of the low end curse word, ta technix, rokko, the cheap FK ones and they were all ok. The Rokko's were particularly harsh but none of them died even after over a year of daily use!
bortaf
Nov 21, 2015 14:34:52 GMT
I've got 3 sets from 2 differant golf all leaking 1 set 3 months but the owner works in a tyre yard is 19 and rags the of it everywhere, actually they all work in the same tyre yard that could be the main factor LOL i'll get the make and let you know
R.I.P photobucket
bortaf
Nov 21, 2015 18:45:28 GMT
bit messy in there ! No name make i'm affraid only a part number If anyone want the springs they are welcome, there's 2 other pair in there somewhere but they went in 5 months before the rest of the scrap so wont find them till scrap prices go up and i empty the garage but those front pair are available FOC )
R.I.P photobucket
820
Nov 21, 2015 19:04:54 GMT
bit messy in there ! No name make i'm affraid only a part number If anyone want the springs they are welcome, there's 2 other pair in there somewhere but they went in 5 months before the rest of the scrap so wont find them till scrap prices go up and i empty the garage but those front pair are available FOC ) I'm interested in the helper springs if they are 2.25" internal diameter
qwerty
Nov 21, 2015 21:24:32 GMT
Cheers for digging them out. Look like generic eBay stuff.
bortaf
Nov 23, 2015 12:55:05 GMT
bit messy in there ! No name make i'm affraid only a part number If anyone want the springs they are welcome, there's 2 other pair in there somewhere but they went in 5 months before the rest of the scrap so wont find them till scrap prices go up and i empty the garage but those front pair are available FOC ) I'm interested in the helper springs if they are 2.25" internal diameter I'll measure when next in there (next week) PM me chap and we'll sort it out
R.I.P photobucket
820
OK thanks
Nov 29, 2015 10:08:22 GMT
They look like JOM Blueline coilovers to me. I've just changed the set I had on my Bora. They lasted four years for me.
Just fitted TA technix. I think the JOMs had a better ride and gave better feedback on the handling. But as mentioned before, for just a bit of fun on track - either set would be fine. You'll be able to set the car how you like in terms of height and weight. The only thing you have to settle on is the dampening and rebound rates. You can always buy different weight springs if you want to experiment.
I've had super expensive coilovers in the past and honestly never got the best out of them as there was so much to set up. In the end I got a firm to corner weight it for me, set the rebounds for "fast road" use and went on my merry way. In my eyes, unless you're building a Time Attack car or dedicated motorsport weapon, the cheap ones are just fine.
