I have had this stashed under the bed for years with the hope of having something to put it on. I have finally figured that's not going to happen any time soon.
This was bought brand new a few years ago with pipe work for £450. The pipe work has since gone and I am left with this cooler unit.
The ends of this Intercooler are one piece pressed, at the time of purchase this was the best thing since sliced bread, however I am sure since then they all come like this. I believe it results in less welds so less chances of leaks or problems developing in the unit.
There is however some damage to some of the fins, I have tried to photograph this as best as possible. If you sit with a tungsten or small pin the fins straighten out fine, but I do not have the time or inclination to do this myself, so as a result you get a cheaper Intercooler that works 100% as it should for less than a brand new one.
I have had a quick measure.
300mm - From the top of the cooler to the bottom
640mm - wide along the bottom from outer to outer
790mm - Wide along the top from each inlet
590mm - Exposed core width
80mm - Deep (actually 3")
80mm - Inlet and outlet (actually 3")
I would like to see £80 for this. This is also listed on ebay but on a collection only basis.
I am happy to ship this to RR members fully insured for £15.
