Darkspeed
Club RR Member Number: 39
Mar 27, 2016 23:33:38 GMT
Fantastic!! Just read the whole thread. I prefer the resurrection of this old kit more than the building of a new kit!! I like your vision. I really wanted a Lister Bell and really looked deeply into it. The quality of their work is way beyond any other kits. Unfortunately as part of my investigations I found that kit cars are as good as outlawed in Germany (where I reside).....bummer. I shall be watching this thread closely. Keep up the excellent work. Some of the rules for kits and replica's are pretty onerous outside of the UK and pleased we have the freedoms that we do even though there are a fair few dissenting voices about the IVA system we have. Having put a car through IVA I must say I agree completely with the process. Thanks for the kind offer Adrian but I don't think there is anything else other than the Fiat 850 lamps that will suit the car so I will just have to accept the pain. The same goes for wheels - there are only one set of wheels that really suit a Strato's and that's a set of Coffin spokes which is a rather larger pain. I am happy with tweaking a few things here and there with the look of the car but you cannot really do much as the overall package is just so right and any changes outside certain boundaries don't work so well Similar chassis to mine has just turned up on the worlds favourite tat site. But as most recent builders of Litton/CAE cars throw the bodywork away there is not a lot visible there that has much worth. www.ebay.co.uk/itm/C-A-E-Corse-Kit-Car-Lancia-Stratos-Unfinished-Project-Alfa-Romeo-164-V6-3-0L-/322053816933?hash=item4afbe74265:g:vFQAAOSwI3RW9~46&clk_rvr_id=1004923947434&afsrc=1&rmvSB=true
googled lights and will check in the box tomorrow, been there for a few years and can't remember exactly what they look like. Got a pair of CF2 lights for the Eagle P21 bodied S3 project as I haven't seen many done... just to be different.
1988 DUTTON LEGERRA MK1 - SPARES DONOR 1989 DUTTON LEGERRA MK2 - CURRENT PROJECT 1990 DUTTON LEGERRA ZS MK2 1990 DUTTON LEGERRA ZS MK2 DUTTON PHAETON S2 - Resting DUTTON PHAETON S4 - Resting DUTTON PHAETON S4 - PROJECT X DUTTON SIERRA S2 - Resting
Darkspeed
Apr 12, 2016 18:04:35 GMT
Darkspeed
Apr 21, 2016 18:49:31 GMT
Yep that's why....
stevietuck
Apr 21, 2016 20:19:00 GMT
Now that really is living the dream
duncanmartin
Out of retro ownership
Club RR Member Number: 70
Apr 22, 2016 18:39:44 GMT
This one is pretty good too:
The Stratos sounds glorious, the Delta is more sensible, but I just love the crazy sewing machine of the 037!
Darkspeed
Apr 22, 2016 19:33:56 GMT
The Stratos sounds glorious, the Delta is more sensible, but I just love the crazy sewing machine of the 037! I managed to give the old Honda lump a bit of a rev early on and it did a passable impression - The short separate exhausts with minimal silencing helps. Those 037's do sound wonderfully manic
Darkspeed
Apr 23, 2016 23:17:29 GMT
The build shed was dry today so I managed to get a bit more done with the rebuild in that I continued to slowly undo the minor neglects whilst at the same time progressing with building up the new bits. Job for this weekend was to get the lifter mechanisms fitted which is accomplished in a few stages the first of which is bonding in very nice stainless bracket that the pod hinges on. Take over the garden furniture for the day and rough up the underside of the bracket with 40 grit in the angle sander and slop on some Black Sikaflex and away we go. Let it lose its tackiness and then paint inbetween carefully .... ....as I had the black paint out giving the inside of the rear clam a tidy up. Apart from buying a couple of tractor light units for the side and indicator that was the extent of the work on the "new" Some of the dirty work involved removing the coolant pipes the brakes lines and the accelerator cable from the central "Services" tunnel. Quite a bit of accrued detritus. Needs a good wire brush out and paint. I also tried a drop of Acetone on the old adhesive covered panels which seems to do the job. It will take a bit of work but they may come up serviceable. As the coolant pipes removed will not take any further part in the future of this car they may as well double up as a test to see if I can fit a couple more stays and a diagonal to the cage. I think that could work as they appear to miss most of the important bits and most of that plenum and throttle body would be gone and clear anyway.
Excellent work!
I really wish that kits were common and affordable in Australia. I like light-weight and basic cars, but they're so rare here that the used prices are hard to justify.
Darkspeed
Apr 24, 2016 19:59:45 GMT
Excellent work! I really wish that kits were common and affordable in Australia. I like light-weight and basic cars, but they're so rare here that the used prices are hard to justify. Cheers - trying to do a little and often now that we are clear of the winter blues. I understand that you have some more involved engineering checks for kits in Australia. I have seen post elsewhere that they check and measure the torsional rigidity of the chassis and there is a fixed value for pounds per degree that needs to be met. Dry in the build area again today so more work completed. That internal panel cleaned up alright with the application of some elbow grease and Acetone so that bit can stay. Lamp box assembly today First off here is an example of the difference between the old and new parts - this is the headlamp lifter adjuster rod. More nice new parts the assembled headlamp hinge mechanism. After a bit of work I had both boxes assembled, nicely symmetrical and adjusted so that no stress were being introduced to the bonnet skin. Got a few more washers and bolts to purchase to complete the work but for a first off basic adjustment I am pretty pleased with the result - A bit of fine tuning is required to get the pods perfect with the bonnet but it looks a simple process with these parts. First off panel closing box for N/S - I need to build a replica of this for the O/S as the original part I have is a replica of the Lancia parts and its a different shape. Lamp pods - Fine adjustment another day. Had a big smile on my face after completing this stage.
Darkspeed
Apr 24, 2016 20:12:48 GMT
As I had a big cheesy grin on my face I thought I would give the car that wide awake look As the Mazda lift motors have a nice little manual lifter button a few turns later resulted in the typical pop up startled look. Dropped a trim on it And then fixed the side-indicator on and took a sneak peek shot I then turned my attention to the back of the car with lots of faffing about on the boot lid hinges - Lots of trimming and trying so will not bore anyone watching this thread with all the detail - just one quick shot of my boot lid simulation rig. End of the day I fitted the other side/inicator and dropped the chin spoiler back on Just wish it was half as complete as it looks.
Apr 24, 2016 20:22:22 GMT
Love the Stratos; you're doing a cracking job and it looks fantastic
Apr 24, 2016 21:49:18 GMT
That's really nice. Properly really nice. Just wish it was half as complete as it looks. Just wish my almost complete car looked half as good as yours!
Darkspeed
Apr 25, 2016 12:43:58 GMT
That's really nice. Properly really nice. Just wish it was half as complete as it looks. Just wish my almost complete car looked half as good as yours! I follow the work you do on your car with a keen interest - Mid engine, pop-ups, wedge - whats not to like and it looks like its coming along pretty well. If you ever want similar but without the tin worm I can thoroughly recommend one of these Plastic body part from the doors)/ Galv chassis and quite fun to drive as they handle very well.
Apr 25, 2016 13:13:18 GMT
Nice thought but Mrs Sweetpea would divorce me. I don't know why she puts up with me as it is. Maybe it's my huge, er, personality.
So the doors look like an early Fiesta. The spoiler on the back reminds me of a Quantum. But, no. You'll have to tell me what it is.
Darkspeed
Apr 25, 2016 15:40:45 GMT
Nice thought but Mrs Sweetpea would divorce me. I don't know why she puts up with me as it is. Maybe it's my huge, er, personality. So the doors look like an early Fiesta. The spoiler on the back reminds me of a Quantum. But, no. You'll have to tell me what it is. Must be my age - I thought I had put the make and model in the text ...Ooops - It's a Ginetta G32 - They are what I spend most of my spare time messing about with (When its not spent on the Litton) as over the past few years I have managed to end up with 5 of them! All of them projects more or less and I guess the G32 is the least of a project of them all. MK2 Fiesta doors but chopped and the quarterlight glass is bespoke. Type approved production car - about 120 produced. The other halves - Mrs Darkspeed - I have her to thank for introducing me to Alfa Romeo - I knew nothing about them until we were driving along the A5 in Edgware and she shouts at me to turn left. - She tells me to stop and I do behind a 2000 GTV Guilia Coupe - In Dutch Blue sat looking very sad under a tree - "Lets knock on a few doors and find out who owns it" she says ....
Last Edit: Apr 25, 2016 15:42:24 GMT by Darkspeed
Darkspeed
Apr 25, 2016 16:02:58 GMT
Love the Stratos; you're doing a cracking job and it looks fantastic Thank you appreciated.
Apr 25, 2016 21:06:28 GMT
What sort of nerd does that make me then? Recognise the doors but not the car! In my defense, I don't think I've ever actually stood next to a G32. To save further embarrassment, in future, I'll refer to cars in the same way that I refer to motor bikes. "Ooh I like the red one! It's got a shiny exhaust!" Best get back to the Stratos maybe... That's the yellow one right?
Darkspeed
What sort of nerd does that make me then? Recognise the doors but not the car! In my defense, I don't think I've ever actually stood next to a G32. To save further embarrassment, in future, I'll refer to cars in the same way that I refer to motor bikes. "Ooh I like the red one! It's got a shiny exhaust!" Best get back to the Stratos maybe... That's the yellow one right? It's The Melon Yellow one to be absolutely correct As for not recognising, or never have stood by a G32, you are not in a minority on that score - If I get time / motivation I may start another thread about the Ginetta's. It may even spur me on to get some further work done on them.
luckygti
I need to try harder!
Apr 29, 2016 22:39:48 GMT
This is coming on so well. I've been clearing out some old kit car magazines and I had a good read about the Gerry Hawkridge / HF series Stratos's this afternoon. They really are such amazing looking cars. I would definitely like to see/hear more about the G32 though, long been a favourite of mine.
