I've been slowly amasssing a small pile of parts that are of no use to me so I'm having a mini clearout to make room for more car tat
All parts are located in Coventry, would prefer collection but can check postage costs on some of the smaller stuff as required (would prefer not to send the carbs as they still whiff of petrol a fair bit)
Also open to offers on everything
First up is some stuff taken from my MGB recently
2x ignition coils: £5
Ones a Lucas Gold coil and ones possibly a Powerspark one from memory? The gold one has a bit of corrosion in the king lead contact. But the black one was working fine when I took the car off the road
Pair of SU HS4 carburettors: £70
These were rebuilt by myself not too long ago and are in great condition. They ran really well on my car before I took it off the road, only selling as I'm either going for bigger carbs or efi. From memory they have slightly richer needles in them as I had the K&N air filters fitted but they're otherwise stock carbs for early B's. No linkage included
MGB HS4 intake manifold: £20
As in the carb photo, bit dirty but worked fine in all the time I was running the car
K&N air filters for MGB: £30
The best air filters for MGB with a standard twin carb setup. Deeper than the flat 'pancake' type filters and give a nice induction noise. Work well with HS4 carbs and I presume they work well with HIF4's too. Quite pricey new
Pair of Horns: £5
Generic RING Hi/Lo tone horns bought from Halfords a couple of years ago to get the B through the MOT, nice tone and work fine, not had much use
Pair of spotlamps: £5
Generic small RING spotlamps from Halfords,think they've got 130w Halfords 'rally' bulbs fitted. Pretty bright and do the job, bit of surface rust on the exterior but worked fine
MGB reverse lights: free
MGB reverse lights, bit tatty but would do the job, outside lip of bezels painted black
5x110 20mm hubcentric spacers: £50
Set of 4 spacers, two have had no use, the other two were used very briefly on the back of my 9-3 before I gave up on it. Centre bore size is 65.1mm
BMW E38 7 Series indicators: £5
OEM amber front and side indicators from my 750i Pre facelift, fiver for the lot, all in good condition. Were only taken off as I fitted smoked items
Mazda RX-7 FC NA Clutch Slave Cylinder: £50
Brand new part, bought in error as only fits NA RX-7 FC models. Part make/number is Blue Print ADM53609.
BBS LM replica wheels: £300
As taken off my Saab, weren't on there for very long. Unsure of brand except one is definitely a Dare BBM as it was bought to complete the set. (They are all identical, the new one just has a slightly different rim bolt design)
I've painted them in Ford Tibetan Gold, polished the lips and lacquered the whole lot. They're in great condition and haven't done many miles since me refurbing them, theres just a couple of small nicks in the lacquer on a couple of the spokes but these are hardly noticeable.
18"x8"
5x112
et42
cb 73.1
3 are fitted with Pirelli P Zero Rosso tyres and one is a Pirelli Cinturato P7. All are 225/40
1 of the P Zeros has about 3/4 mm tread left
The other 2 P Zeros have 5mm
The Cinturato has 7mm
18"x8"
5x112
et42
cb 73.1
