Feb 24, 2016 10:13:18 GMT
Hi all, have been in the process of making a manifold as described in the title. It's nearly done now so thought I'd make a little thread for it in case people were interested First step was to buy a tig welder and learn how to tig weld! Haha Bought a load of butt weld pipes from eBay and used an old flange I had. Cut and positioned them: My first couple of goes at welding tig Think I'll get my coded welder friend to get things started lol
Last Edit: Feb 24, 2016 13:36:47 GMT by code109
Feb 24, 2016 10:35:51 GMT
Whilst I waited for my friend to do that, I got on with things that had less pressure on them, namely the downpipe form the turbo... V-band welded to the first stainless section: And welded as much as I could without it being on the car for measurements:
Feb 24, 2016 10:37:41 GMT
Friend dropped this off to me!!!! Skimmed it flat in work that night:
Feb 24, 2016 10:41:22 GMT
Just need to cut these parts out: Et viola: Cut and stick two bits of stainless angle together: And weld a T3 housing flange to the result: And stick that to the manifold:
Feb 24, 2016 10:43:04 GMT
How it looked so far: Just need this here now:
Feb 24, 2016 10:48:07 GMT
Welded the wastegate pipe and flange on: Just needs dump pipe welded to the downpipe now, and then I can put it on the car and finish the downpipe, and put a bung in for the O2 sensor: That's as far as I've got atm, hopefully get more done tonight Craig
Last Edit: Feb 24, 2016 10:48:55 GMT by code109
Feb 24, 2016 15:57:59 GMT
Very impressive. What's it being fitted to?
Feb 24, 2016 21:17:12 GMT
I'm hoping you and your mate purged the manifold when it was being welded for your sake,
Feb 24, 2016 21:40:16 GMT
Yes was all back purged don't want any black curse word shattering my turbine!
LAndy
Sorry for the amateur question but what does the purging do?
Previous retros: 92 AX GTi 92 Scirocco Scala 94 80 sport 87 Golf Cab GTi Current retro: 1965 Clark Cortez YouTube Website Instagram
With tig welding, the argon gas coming out the nozzle shields the tungsten tip and filler rod and weld itself as it cools, flooding it with argon prevents air from contacting it all, stopping it from oxidizing
If you're welding pipe like this, the weld will penetrate and burn though the metal to the other side, which, if it isn't protected by argon, will oxidize, go all curse word and possibly crack later on! So filling the tubes with argon stops that
Last Edit: Feb 25, 2016 9:29:20 GMT by code109
Also if there's oxidization inside the manifold, it's possible little bits could chip of and go into the turbine of the turbo which wouldn't end well at all
LAndy
Feb 25, 2016 12:56:44 GMT
Thanks for that!
Feb 25, 2016 17:13:16 GMT
It goes all black and scaley where you burn through a backing gas stops this
Feb 25, 2016 18:12:27 GMT
Just trial fitted stuff tonight so I know where to weld the dump pipe to the downpipe... fits quite well I think
hario
S202 C300STD
Mar 15, 2016 14:15:44 GMT
Nice#!
