Club RR Member Number: 160
Mar 26, 2016 18:47:22 GMT
So I have acquired a Panasonic F35 for the BMW- (I assume) it has a DIN 8 pin output on the back, a lá- I would like to adapt it to RCA, much like this- I can get one of those but only from America for about £40, which seems a tad much as if I had the pin-out I could easily make that. Anyone got any clues or help? Cheers!
g40jon
Mar 26, 2016 19:16:14 GMT
I would suggest researching on google. You might find that it uses the same pin-out as blaupunkt who also commonly used din back in the day. There is lots of info out their for old blaupunkt gear, less so for panasonic in my experience. Other option would be to open the radio up and trace the wiring back to the relevent ic, the google the ic part no, to find the pin out for that.
squonk
Mar 26, 2016 20:04:40 GMT
I had a dig through my old service info (I used to be a car audio fitter in the 80's)and found this which I think is the correct diagram for you:
gazz81
Mar 26, 2016 21:06:22 GMT
squonk
Mar 26, 2016 21:09:31 GMT
Did you read the original post?
"if I had the pin-out I could easily make that"
gazz81
Mar 26, 2016 21:14:52 GMT
Nope, but thanks for bringing it to my attention.
I had a dig through my old service info (I used to be a car audio fitter in the 80's)and found this which I think is the correct diagram for you: Ace, me and James are gonna have a poke with a meter and see what we can find, so having an inkling as to what MIGHT do what is a great help
Mar 27, 2016 10:57:19 GMT
Last Edit: Mar 27, 2016 10:58:00 GMT by mdh
Koos
Mar 27, 2016 14:34:08 GMT
Close but I have 8 pin male. I'm going tomorrow so will have a look anyway
Last Edit: Mar 27, 2016 20:01:55 GMT by Rich
