adam73bgt
Club RR Member Number: 58
Apr 19, 2016 22:42:07 GMT
Bought an exhaust for my RX7 recently, its used but most of it is in not too bad shape, however the pre silencer is probably the worst bit The main issue I have is that theres a stud snapped off in it The other studs aren't looking particularly amazing but might clean up ok Essentially I'm looking for someone near to Coventry that would be able to get this out and put a new stud in for me I'd take it to a garage but I have a feeling it would either get lost/thrown on the scrap pile or I'd get charged a silly amount to sort it Any suggestions anyone?
Last Edit: Apr 20, 2016 18:16:56 GMT by adam73bgt
taurus
Sorry I am too far away from you - I'm guessing you're not after ways to do it yourself because it isn't a hard job if you've got the right tools - I'll bet there's someone on here who can do it for you easily enough. If not a local machine shop would tackle that very quickly - probably a better bet than a garage.
Wilk
Clean up the studs as much as possible then heat the surrounding flange until glowing red at base of studs
Clamp studs tight with mole grips. It'll turn out or through. Try both directions. Once it starts to move, get some lube around the edge of the hole to help it along. I use this method regularly to refurb m/c exhausts and it rarely fails
Failing that it's either drill it out and retap or spark erode
HTH
Last Edit: Apr 20, 2016 8:05:46 GMT by Wilk
adam73bgt
cheers taurus Yeah I don't really have the tools to heat it up at the moment and have a go at sorting it myself so was hoping there'd be someone nearby who could do it or recommend a machine shop as you say. It can be tricky to find the little machine shops is the issue! Wilk Cheers for that, if I had access to something to heat it up enough I'd have a go myself but don't really have anything to do it with unfortunately
bortaf
Apr 20, 2016 14:15:02 GMT
As said, heat is your fried in these cases, MAP is better than propane, then again OXY is better than MAP but MAP is the easyest to get in small amounts from BQ ect
R.I.P photobucket
Wilk
Apr 20, 2016 19:43:52 GMT
Just a tip if you can't grip the stud right enough with the grips....
Turn the flange upside down and grip the stud in a large vice, apply heat then rotate the part around the stud!
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Apr 21, 2016 17:03:04 GMT
If you fancy a ride over to Daventry, I'll have a go at that for you
adam73bgt
Apr 21, 2016 19:02:38 GMT
That works for me MrSpeedy ! I'll send you a message in a bit cheers
Apr 21, 2016 21:50:48 GMT
Rather than trying to grip the stud I find it's better to put a nut over it and weld it to the stud, then use an appropriate socket to try and undo it. Less chance of it slipping and the heat from welding may help free it off a little too
Apr 22, 2016 11:32:14 GMT
I'd linish it flat, centre ounch and drill then tap.
shin2chin
Apr 23, 2016 13:58:18 GMT
I'd second that. These have saved my bacon a number of times
