Jun 10, 2016 11:21:53 GMT
My Volvo 940 as standard uses what appears to be some sort of pipe from the turbo to the actuator which has a cloth type finish. I put my MBC on and it came with some rubber pipet to replace it with.
I've had some issues with incorrect boost readings (not sure why) and I want to make sure that the pipe I am using is correct. I assume that if there is a vacuum possible in the system you need a pipe which can't compress, which the rubber pipe can do.
I can't seem to find exactly what I should use - I need 4mm ID stuff and I don't mind paying for decent stuff, but would prefer black!
The Millenium Volcon"Get yourself a Volvo if that's what you really want, you might be dead next year. In the meantime, you could be going sideways in a gigantic land barge."
Jun 10, 2016 11:24:11 GMT
Jun 10, 2016 11:32:32 GMT
You wont be dealing with compressing pressures on the hoses. That stuff is on ebay so much cheaper and in any colour. Just get the same length and bore you have now and replace.
Nathan
Club RR Member Number: 1
Jun 10, 2016 11:36:09 GMT
I bought some from ASH on eBay and had to send it back. My MAP senor was giving odd readings and the car would not fuel correctly on anything other than what, turns out the pipe was collapsing under vacuum.
Jun 10, 2016 11:59:21 GMT
I bought some from ASH on eBay and had to send it back. My MAP senor was giving odd readings and the car would not fuel correctly on anything other than what, turns out the pipe was collapsing under vacuum. What did you use instead? There's a million sellers of this kind of stuff!!
Jun 10, 2016 12:09:11 GMT
Really, I wouldn't have thought it would be remotely near collapsing pressure. Thats interesting
Jun 10, 2016 12:14:04 GMT
Me too, but if I get stuff that doesn't compress I will know it won't be a problem at all.
alecf
Jun 10, 2016 22:49:26 GMT
I've used ash for all my build and had no issues
Nathan
Jun 13, 2016 14:07:29 GMT
All my boost pipes are ASH, they are fantastic quality for the price. When this one arrived it felt more flexible (I'll get a photo as I kept a an offcut), very thin walled like a children's drinking straw. When I flagged it with them they mentioned it being an issue with certain stock and sent a replacement.
It's just worth keeping in mind as I ran for weeks with that attached and wondered why the readings were severely off.
hario
S202 C300STD
Jun 16, 2016 18:32:49 GMT
My Volvo 940 as standard uses what appears to be some sort of pipe from the turbo to the actuator which has a cloth type finish. I put my MBC on and it came with some rubber pipet to replace it with. I've had some issues with incorrect boost readings (not sure why) and I want to make sure that the pipe I am using is correct. I assume that if there is a vacuum possible in the system you need a pipe which can't compress, which the rubber pipe can do. I can't seem to find exactly what I should use - I need 4mm ID stuff and I don't mind paying for decent stuff, but would prefer black! Yet to find anything as good-a quality as going to a breakers and getting a few lengths of OEM boost actuator hose
chubz
Jul 11, 2016 11:28:09 GMT
surely samco hoses will be up to the job
Jul 11, 2016 14:36:03 GMT
Yup, Samco after speaking with a known hose manufacturer for a classic hose company (amongst others) have a good construction regarding the ply etc. What bore of hose do you need? I can see what can be done locally .
Jul 11, 2016 17:15:43 GMT
Why not use plastic air line and just use silicone bits at each end.
