There's been quite a lot of talk about car care lately so i thought I'd share this.
A good friend of mine, and RR forum member sparkysparks came over with his cool Nissan after reading about clay bars and wanting to find out what they do.
We went through the whole safe wash process, a quick polish and some protection.
Here's how it went...
First up, wheels.
Wheel back, faces/spokes, tyres and arches.
The car gets a snow foam mix as a pre-wash to soften the dirt on the surface.
While that gets to work we use an all purpose cleaner and some soft brushes to clean out all the tighter spots and rummer trims and seals.
The car is pressure rinsed and then washed with the 2 bucket method (one bucket with the shampoo solution to wash the car - one bucket of clean water to rinse the wash mitt.)
Dried with plush microfiber towels. There was a car waiting inside, otherwise we would've done this out of the sunlight.
Inside we went through the different clays, the pros and cons.
We used the clay from @buffinstuff with a Meguiars rinseless wash as lubrication.
A quick demo and then Mark got to work claying all of the bodywork and wheels.
You can see what the clay has picked up n just a small section of the bonnet.
Working around the car.
Once the car was complete, we applied an all in one polish using a microfiber applicator pad. (Auto Finesse Tripple)
This has chemical cleansers, light abrasives to take the edge off of any swirling, fillers to mask the defects a little and a bit of protection to leave behind.
A layer of ODK Wax Eclipse was used for some more durable protection on the now nice and clean paintwork.
The exhausts were still a little grubby.
Polished with Auto Finesse Mercury.
The wheels received a coat of Auto Finesse Mint Rims to help prevent brake dust and dirt sticking so much, as well as making them much easier to clean in the future.
The glass was cleaned, tyres dressed, interior hoovered and cleaned up a little.
The finished results.
If you have any questions about any of the products, procedures etc. fire away
Thanks for reading!
First up, wheels.
Thanks for reading!
