elfman
Jun 22, 2016 18:53:30 GMT
A set of 4 CX Compomotive Wheels 7" x 13" with a 4" PCD back measurment of 106mm so don't stick out like Carlos Fandango wheels. Also a full set of the chrome lock nuts. Rare wheels these days as they are no longer made and in good condition. £250 + P+P. Please PM me for more pics & info if needed. I will remove the old tyres before sold.
Last Edit: Jun 22, 2016 19:14:20 GMT by elfman
elfman
Jun 22, 2016 19:12:02 GMT
harris
Jun 23, 2016 19:43:35 GMT
Hi what does a 4" PCD fit cheers matt
Last Edit: Jun 23, 2016 19:43:59 GMT by harris
Jun 23, 2016 20:48:52 GMT
4x100, VW, Vauxhall, 90's Renaults, 80's BMW's and many more hope that helps a little bit
harris
Jun 23, 2016 20:53:41 GMT
Cheers mate , was hoping 4x108
elfman
Jun 23, 2016 22:05:22 GMT
4" is about 101.6mm if i remember they should not be fitted on 100mm studs. They fit Mini, Imp, early Viva. Morris Minor.
4" is about 101.6mm if i remember they should not be fitted on 100mm studs. They fit Mini, Imp, early Viva. Morris Minor. Ignore me then haha! close but not close enough
elfman
Jun 24, 2016 12:57:42 GMT
lol what did they say "close but no cigar" ! I have known people in the past try and fit them but its not a good idea..
Jun 25, 2016 15:50:47 GMT
Any reason they wont go 4x100 with wobble bolts (not that i am an avid fan of such things mind)? The seats arent tapered maybe (cant quite make it out in the pic)
Jun 25, 2016 16:16:12 GMT
you can fit 4x101.6 to 4x100 cars with the use of wobble bolts. But that's with the use of BOLTS do not do this with studs as you just cannot.
elfman
Jun 25, 2016 19:51:25 GMT
These wheels come with Compomotive sleeve nuts so no taper, I would never trust wobble bolts.
Jun 25, 2016 20:12:16 GMT
Thought so regarding sleeve nuts, thanks.
I fitted 4x100 watanabe SSRs on 4x101.6 hubs in the past by making spigot rings and taper wobble nuts (not bolts) for them, worked a charm, but i do take your point and it is far less desirable.
Beetlejuice
Living rent free in heads since…
Jun 26, 2016 10:10:41 GMT
Pm inbound
Stuck in the 90’s - mostly minis
elfman
I have excepted an offer for the wheels will confirm if the sale goes through ASAP.
elfman
Now been Sold..
