All are brand new in box (unless noted), prices plus P&p
DEI Reflect a gold heat tape 1.5" by 30 foot roll £55
DEI Reflect a gold sheet 24" x 24" £55
MSD street fire Universal ignition leads part no 5552 £40 (comes with 9 leads and crimping tool so you can cut to length)
MSD street fire Universal ignition leads part no 5553 £40 (comes with 9 leads and crimping tool so you can cut to length)
Titan Ratcheting Spanners (pretty much identical to the Halfords Pro line spanners) 7pcs metric £30
Titan Ratcheting Spanners (pretty much identical to the Halfords Pro line spanners) 7pcs imperial £30
Silverline brake line flaring kit £9
Silverline 3pc gearpuller set 75mm 100mm & 150mm £9
SIlverline petrol compression tester £10
HArmonic Balancer puller set £10
Threaded Rivnut Gun (4 5 6 & 8mm)£10
Angle Torque gauge £4.50
4" 4.5kg engineers vice £20
Universal speedo cable inner 113" £12
ThermoTec Micro Louver Heat shield 1ft x 2ft (pat no 11710) £40
Genuine Bosch WIdeband sensor LSU4.9 (note these will not work with LSU4.2 controllers) £50
Full DIY Autotune Megasquirt MS3 kit complete with MS3X expander board (build it yourself kit) £450
MS1 Main processor chip (part no U1 in megasquirt manual) £40
FSE Powerboost Adjustable EFI fuel pressure reg £30 (no box, 3/8" tails)
Rover V8 Dual valve springs x16 £80
Rover V8 Triple Valve springs x16 £50 USED
Rover V8 Federal Mogul Solid Steel Rocker Arm setup complete £200 (good for 7000rpm according to the PowerTune RV8 book)USED
Rover V8 Rovertec/Mark Adams Adjustable ECU for Flapper/4CU injections systems £250 USED (allows tuning of cruise and W.O.T fuelling, good to over 300hp)
Rover V8 Boxer Quad Carb Setup complete with manifold, 4x HIF44's, balance pipes, fuel lines (aeroquip), throttle linkages and thermostat housing USED £400
Apexi VAFC2 with Plug and Play adapter loom for Honda OBD2A (DC2 ITR or similar) USED £200
