Hi, I have a 1976 Ford Pinto Station Wagon with a Cologne 2.8 V6 in it. At some poine somebody has fitted an efi on instead of the carb.
The car would not run correctly so I have removed the efi and put a Webber 38DGAS carb back on. I have fitted a Bosh distributor and would like to know how to hook up the wiring.
There is a green and a black wire coming from the coil.
There is a purple an orange and a black coming out of the dizzy.
The connector that was connected to the dizzy used when the efi was fitted has several wires - green - black - blue - blue/yellow - blue/red and what looks like another black
Obviously the blacks connect but which do I connect the purple and the orange to?
I have uploaded some pics for reference
Last question - could I use the dizzy fitted to the efi set up as it looks identical except the shaft is longer so it cleared the efi plenum
