LowStandards
As per the title We need some wide 13'' steels for the Panda Drag Car We want to run 185+ tyres so they've got to have some girth to them, but they've gotta be steel to keep with the 'povo spec' look! Some pics for inspiration
stinkwheel
Doctor Of Gonzo Journalism - One of gods own proptypes, never even considered for mass production.
pretty much every other fiat.
1973 Citroen Dyane 6 1980 Citroen Acadiane 1992 Citroen AX 1990 Citroen BX 1997 Citroen XM 1993 Citroen BX 1997 Citroen Xantia 1977 Citroen Ami 8 1996 Ford Escort 1989 Citroen BX 1997 Suzuki RF900 1988 Yamaha TDR250 1979 Honda CB400. 'I need less vehicles'
all modern 4 stud Alfas (33/164/155 etc..)
71 Alfa GT 1300 Junior 89 Alfa 75 3.0 V6 Veloce 89 Alfa 75 3.0 V6 America 2015 C220 estate Daily shunter
best bet is to use wobbly bolts (might not trust them, but they'll help) to bring your PCD to 4x100...
The journey of 1000 miles starts with a single coffee.
I don't like coffee!
Odin
You'll probably struggle to find anything with decent width in 4x98. I think your likely options will be the following, although I prepare to stand corrected:
5x13s off a Punto. 5.5x13s off a VW (possibly Mk3 Golf/Vento).
Step up to 14s and go with a 6x14, off Passats etc.
Obviously all the 4x100s will need wobble bolts or similar. You might have more luck with older Alfas, but I don't know about those.
best bet is to use wobbly bolts (might not trust them, but they'll help) to bring your PCD to 4x100... why ? he's after steels - you can get 5.5 & 6" wide alfa steels no problem
4x98 also used on 4stud lancias I believe.
Weren't there a few quick Delta's and the old fast Y10 about in the past.
Just a thought, but that company that bands steelies. See if they will do it, in exchange for their name on the car. Get it sponsored before it is even built.
either that or cough up three times the budget for the whole car just to gett he wheels done...
BiAS
Insert witty comment here
Club RR Member Number: 147
What shares a 4x98 pcd?BiAS
@cheeqi
Club Retro Rides Member 147
Aren't newer alfas 100, not 98? I've been looking for some cheap 6 or 6 1/2 x 13 steels for mine and haven't had much luck. As has been said, see if you can blag some wobbly bolts in exchange for a bit of publicity?
(car+wheels)-rideheight=WIN
dave7
Anyone have an online source for these wobbly bolts? I'd like to use a set of 4x110mm wheels on 4x108mm studs.
LowStandards
I think they'll only work on studless hubs, though someone may correct me???
slater
Club RR Member Number: 78
What shares a 4x98 pcd?slater
@slater
Club Retro Rides Member 78
You can get 'wobble nuts' too
same principle but with nuts
Ladas also have same PCD as Fiats. Niva 16 inch steel rims with low profile rubber would look smart. With Lancia rims be careful not to end up with some really cheap but useless metric rims.
Vitesse 6 Saloon Vitesse Mk2 Convertible BMW R1150GS VW Amarok
Aren't newer alfas 100, not 98? no
Ladas also have same PCD as Fiats. Niva 16 inch steel rims with low profile rubber would look smart. With Lancia rims be careful not to end up with some really cheap but useless metric rims. apart from them being 5 stud and of 4x4 centre size.nivas are the same as vitaras and other suzuki jeeps.
