Sept 14, 2016 21:39:19 GMT
My mk1 Cav is running a Weber 32/36 DGAV,been running rough so stripped it all down,cleaned,replaced all the jets.
Tickover is fine but once over 2000rpm what I can only describe as the sound of the exhaust coming out of the cards?!?!
The car is well done on power to.Any advice much appreciated.
Club RR Member Number: 160
Carb noise???Rich
@foxmcintyre
Club Retro Rides Member 160
Sept 14, 2016 22:39:57 GMT
My mk1 Cav is running a Weber 32/36 DGAV,been running rough so stripped it all down,cleaned,replaced all the jets. Tickover is fine but once over 2000rpm what I can only describe as the sound of the exhaust coming out of the cards?!?! The car is well done on power to.Any advice much appreciated. Sounds like timing. Not the carb.
slater
Club RR Member Number: 78
Carb noise???slater
@slater
Club Retro Rides Member 78
Sept 15, 2016 0:08:10 GMT
Sounds fine to me? Carbs are supposed to make noise.
Sept 15, 2016 3:06:12 GMT
OE air filters housing act as intake silencers as well as filtering air. If you have an aftermarket filter, such as K&N, then the intake "roar" will be more noticeable
Sept 15, 2016 6:20:08 GMT
Prob the 2nd choke just opening a little bit causing a lot of air noise through a restricted opening
