Sept 19, 2016 15:00:46 GMT
So. Not content with the Avenger Race car i decided i needed more car in my life so last year i went to Scotland and picked this up: IMG_0301 by Nevtiger, on Flickr It is a 1.3 LS in stunning Sweetcorn and orange tartan and brown interior. The plan is as follows: - Restore body work
- Seam weld and fit strengthening kit
- Fit roll cage
- Fit refurbished original interior.
- Fit AJ30 V6, 6 Speed ZF manual box and Volvo 1031 rear axle
Then enjoy it as any pampered Classic should be.
Last Edit: Oct 21, 2016 8:33:32 GMT by nevtiger
Sept 19, 2016 15:27:53 GMT
Nice! I like Sunbeams, so I'll be following this. You say it came from Scotland, did the car happen to come from a man who has loads of them in various guises, and is in the cement business?
96 Peugeot 405 Executive DTurbo Estate 89 Mazda Eunos Roadster 88 Citroen BX 16RS Previously Owned: 93 Subaru MV96 Disco 300TDI 72 LR SIII 109" Prima96 Xantia Activa 92 AX GTI 97 ZX Temptation 88 205 XS
Sept 19, 2016 15:35:47 GMT
that'll be a giggle then!! about 20 years ago I bangered a totally rotten 1600 that I took back on a px (+ £300) against a freebie samba that id been given to race. win win really...though it never did it was a fun drive!
skozra
Sept 19, 2016 16:46:01 GMT
Great cars - an old college friend of mine had two of these back in the late 80s. One of them was a Ti rally car, lots of fun
93 Volvo 240 Torslanda Estate, 01 Subaru Impreza WRX Saloon & 86 Ford Capri 2.8i (with Weber 38 carb fitted)
qwerty
Club RR Member Number: 52
Sept 19, 2016 16:49:26 GMT
Oooh this sounds like a good project! Keep us upto date.
Is the AJ30 the 3.0 V6 found in the Jag S type?
Tom
Sept 19, 2016 16:50:11 GMT
Back in 1988 when i left school started work at the local Peugeot/ Talbot dealer one of the mechanics had a bright red Ti version with Duck Tail spoiler. I was impressed by this and later owned it's bigger brother.....of sorts, the Horizon.
1980 Vauxhall Cavalier MK1 1970 Mobyleete 40T custom 1978 Mobylette 50V 1965 Moulton Standard 1979 Raleigh Grifter custom 1980 Raleigh Grifter 1982 Raleigh Grifter BMX custom 1982 Raleigh Bomber 1987 Strida
Sept 19, 2016 17:12:34 GMT
Oooh this sounds like a good project! Keep us upto date. Is the AJ30 the 3.0 V6 found in the Jag S type? Tom Yes it is, i have an early engine with the on/off cam phasing.
Sept 19, 2016 17:14:17 GMT
As it happens i have had in the past one Series 2 TI and two S1 Lotus Sunbeams. Each of those were good in their own way so i want to create my own version of what i think a Sunbeam should be....................
Sept 19, 2016 21:38:15 GMT
I had a Ti with a hot 2L pinto engine and a roll cage. It was running a diff from a 1.1 as the original one exploded. It would only do about 84 mph flat out, but it got there very quickly.
1955 Austin A30 1981 Jawa Mustang 1990 Trabant 601 (Tommy) 1989 Trabant 601 2009 Jaguar XF 2012 Toyota AYGO 2018 Scomadi TL
borcombe
Newport, Northern Beaches
Sept 20, 2016 8:05:12 GMT
Bookmarked.Liking the look of the plans. Had a TI many years a go.
Sept 20, 2016 15:59:20 GMT
Nice! I like Sunbeams, so I'll be following this. You say it came from Scotland, did the car happen to come from a man who has loads of them in various guises, and is in the cement business? The chap does have lots of Sunbeams and a few other Classics as well! Not sure if he is in the Cement business - I thought it was BIG garage doors!!
Sept 22, 2016 9:17:26 GMT
Having got it home i had a really good look over the car and its remarkably clear of any major rust at all (this is going to change!). The 5 pieces of rust are shown in the following photos will all take a patch and don't need panel replacement at all! (yeah right - you wait till later) The biggest bit is the passenger door bottom, but as i have a set of S2 doors in stock i may fit these instead. The interior is in fine fettle and with really good clean will be good to go apart from the dash top which has lost its colour sadly. IMG_0316 by Nevtiger, on Flickr IMG_0318 by Nevtiger, on Flickr IMG_0319 by Nevtiger, on Flickr IMG_0329 by Nevtiger, on Flickr IMG_0330 by Nevtiger, on Flickr IMG_0331 by Nevtiger, on Flickr IMG_0332 by Nevtiger, on Flickr IMG_0333 by Nevtiger, on Flickr IMG_0339 by Nevtiger, on Flickr IMG_0340 by Nevtiger, on Flickr IMG_0343 by Nevtiger, on Flickr IMG_0346 by Nevtiger, on Flickr IMG_0352 by Nevtiger, on Flickr IMG_0355 by Nevtiger, on Flickr
Sept 22, 2016 9:18:44 GMT
aking the car apart has been carrying on slowly to check everything for re-use and then given a good clean: IMG_0368 by Nevtiger, on Flickr
Sept 22, 2016 9:23:37 GMT
With the end of the season for OPK (this was written a while ago......) my attention turns to Mr T: I have decided to use the original doors even though they are not as in a good as condition as my series 2 doors for reason of trim and mirrors and now i have a full set of Green Glass too. Starting with the passenger door we see this: image by Nevtiger, on Flickr image by Nevtiger, on Flickr image by Nevtiger, on Flickr Thats a bit crusty so i need to start cutting some of it out: image by Nevtiger, on Flickr Thats with the bottom skin removed ready to cut the frame rot out. image by Nevtiger, on Flickr Not so bad on this corner but still some cut away and all along the bottom of the door. Right now to start the slow process of learning how to shape metal and let it in so nobody can tell.............
Sept 22, 2016 9:35:57 GMT
The passenger door is now done and proved quite a job to remake all the bottom, this is my first time at making new 'parts' so i started with some where where people are not going to be looking too much..... SO i started on the easier end first! the right hand corner has been welded in and was easy to make, then the bottom return: IMG_0972 by Nevtiger, on Flickr IMG_0971 by Nevtiger, on Flickr IMG_0402 by Nevtiger, on Flickr Weld and more weld. As it happens i did not start at one end and carry on like that it was tacked along its whole length, honest: IMG_0403 by Nevtiger, on Flickr Then started to be cleaned up, i bought myself a power file. Glad i did, what a tool: IMG_0405 by Nevtiger, on Flickr So with the easy bits done it was down to the other end and have a go at double compound curves.......... In the end i made the part three times before i was happy and even then i had to do it in two sections to get the curves right: The inside edge still needs to be turned up and this is what gave me so much hassle: IMG_0973 by Nevtiger, on Flickr IMG_0974 by Nevtiger, on Flickr I don't think i will get a job doing this sort of thing yet! but it will be strong and will look good when the door is shut..... IMG_0404 by Nevtiger, on Flickr All done and ready for the skin: IMG_0406 by Nevtiger, on Flickr After finishing the door it was time to start on the drivers footwell as this again will be hidden but this time under the carpet so a chance to do some more practice............ IMG_0983 by Nevtiger, on Flickr Not looking forward to getting my head in there to try and see what i am welding and it proved to be bloody hard. At least the jacking point looks good from the inside: IMG_0985 by Nevtiger, on Flickr
Sept 22, 2016 12:12:07 GMT
like !
read the most bizarre thing yesterday, the slightly larger horizon was the basis for the 1980s version of dodge charger.
need a lie down.
Sept 22, 2016 12:55:16 GMT
Nice work. I had a very rough 1.6 LS in about 1989,it was rotten everywhere but went really well.
I remember being quite suprised the engine had Rootes Group stamped on it,was that normal for Sunbeams?
Sept 22, 2016 13:30:17 GMT
like ! read the most bizarre thing yesterday, the slightly larger horizon was the basis for the 1980s version of dodge charger. need a lie down. Good grief.......
Sept 22, 2016 13:31:28 GMT
Nice work. I had a very rough 1.6 LS in about 1989,it was rotten everywhere but went really well. I remember being quite suprised the engine had Rootes Group stamped on it,was that normal for Sunbeams? Yep - the Sunbeam is a re-panelled Avenger with 4" cut out of the floor pan. A bit later in this thread you will see the seam welding of that join.......
Sept 22, 2016 18:49:38 GMT
Regarding the dash, could Vinylcote be used? I think it can be mixed to any colour....this may be worth looking in to.
