johnd
Hi
I have a scimitar axle, want to do a disc conversion on it, what do i need? Any guides or info?
Cant seem to find a great deal on google
scimjim
Club RR Member Number: 8
Oct 26, 2016 20:04:38 GMT
I think there's at least one on v8 church - may be something on scimitarweb too? I have one you can look at if you're nearby (but I didn't do the work) - IIRC it's VW calipers and a Rover 800 disc?
chrismc
Yorkshire and The Humber
www.redhouseclassics.com
Oct 26, 2016 20:21:57 GMT
Did this a few years ago. From what I remember I used Calibra rear discs and Sierra rear calipers. Brackets were home made and welded in situ once the offset of the disc was established.
Have a look at my restoration blog...www.redhouseclassics.com
johnd
Oct 26, 2016 21:08:49 GMT
See everything i find is mix match with no real guide lol
I need a, you jeed this, this and this.... and do this and this
scimjim
Oct 26, 2016 21:27:34 GMT
scimjim
Oct 26, 2016 21:30:29 GMT
Last Edit: Oct 26, 2016 21:32:44 GMT by scimjim
chrismc
Oct 26, 2016 21:49:54 GMT
See everything i find is mix match with no real guide lol I need a, you jeed this, this and this.... and do this and this What more info do you need? Remove original drum and brake shoes, cut off old back plate, drill Calibra discs to stud pattern and fit, obtain Sierra calipers, make bracket to hold caliper in the correct place as in picture. Hardly rocket science...😄
Last Edit: Oct 26, 2016 22:02:00 GMT by chrismc
