In some shots it looks like Baltic Blue, but the shots do make it look a little 'off'.
There is a chance that the original colour was mixed incorrectly. I had this happen with my Triumph Stag. A specialist felt was Leyland White 19 but Leyland did look more old English. In the end I went to Painstore in Leamington where they confirmed it was Leyland 19 but gone wrong a little. They tinted it to the pattern and where I had the car painted you would not be able to tell the match was that good.
If it were me I'd be looking for a paint supplier to match it up. These suppliers can also supply in rattle cans but they generally need a panel to work off. The fuel cap for instance would be fine.
In some shots it looks like Baltic Blue, but the shots do make it look a little 'off'. There is a chance that the original colour was mixed incorrectly. I had this happen with my Triumph Stag. A specialist felt was Leyland White 19 but Leyland did look more old English. In the end I went to Painstore in Leamington where they confirmed it was Leyland 19 but gone wrong a little. They tinted it to the pattern and where I had the car painted you would not be able to tell the match was that good. If it were me I'd be looking for a paint supplier to match it up. These suppliers can also supply in rattle cans but they generally need a panel to work off. The fuel cap for instance would be fine. Sounds like it may be a case of that. It also looks a bit like cobalt blue but mines a bit lighter. God knows what colour it is. I have the rear valance in the shed because it's broken so might get somewhere to take a sample from that. I'm hoping that whoever does the paint can also supply rattle cans or the mix up so I can have some spare to myself incase I need to do any extra wee bits!
I presume the build sticker is not on the boot floor?
I would be rich if i had not spent so much money on Cars and fast women...oh, i did waste some of it as well!
I presume the build sticker is not on the boot floor? It used to be Sapphire blue metallic but was re-sprayed it's current shade of blue in 2011. Totally different to the original colour so no dice
as ChasR says..looks like Baltic on the inside photos...not so much on the outside ones:(
I use a place called Car Paint in Liverpool, any good car paint shop will match it for you. If it's a Porsche colour, they should find it.
Dec 10, 2016 18:13:11 GMT
I use a place called Car Paint in Liverpool, any good car paint shop will match it for you. If it's a Porsche colour, they should find it. Excellent. I'll get that done after Christmas and see if they can figure it out. Theres a couple of paint shops near me.
