I've had this for a while and TBH I will not use it. It's time someone else had this.
This EWP is an electric water pump, designed to replace your factory belt driven 'pump. I had one on a Dolomite Sprint and it worked very well. I also had one on my RST as a chargecooler pump which was this very item. It was massively overkill and it's time it went on to someone else who will use it.
It works fine. This was run off a relay and a switch. You can run it either like this or with a resistor setup (info is available on Davis Craig's website) so as to slow down the flow of water or with Davis Craig's very own controller.
£60 takes it.
£60 takes it.
