sonus
Feb 21, 2017 13:50:49 GMT
I am having some flanges cut to make an intake and exhaust manifolds for my Daimler V8.
I am considering both stainless, mild steel and aluminium for the intake manifold. Which thickness should I have these cut in for each material?
For the the exhaust it'll be either stainless or mild steel - what thickness should these be?
And where can I get megaphones made that are Inner Ø28mm one side and inner Ø40mm the other side with a length of 175mm?Or is this easy to make out of a flat piece? If so how?
hario
S202 C300STD
Feb 21, 2017 21:48:18 GMT
1/2" or 12mm minimum, otherwise too bendy
sonus
1/2" for stainless and mild steel aswell? For aluminium I was considering 10mm for the inlet.
Feb 22, 2017 13:10:41 GMT
Most production cars with welded manifolds seem to be around 8-10mm, might be worth getting them a bit thicker though so you can get them machined flat if they distort during welding.
Feb 22, 2017 18:04:32 GMT
Ones I've bought in the past have been either 8mm or 10mm
1992 240 Volvo T8 1955 Cadillac 1994 BMW E34 M5 (now sold ) 1999 BMW E36 sport touring x2 1967 Hillman imp Californian "rally spec" 1971 VW bay window (work in progress) 1999 Mazda 323F 1987 Jaguar XJ12 All current
Feb 22, 2017 18:32:43 GMT
I work with inconel manifolds for Nascar F1 and WRC etc and there flanges are 4 to 6mm..
However in the real world I would say 10mm minimum you must always have the flange bolted to a block of metal preferable alloy as it disipates the heat...
A spare head is perfect for this.
Tac the primaries and work through the secondries etc but always split each pipe frome the flange to fully purge weld it..
Theyou can make adjustments for each pipe as they move because they will move....
Mar 16, 2017 22:32:35 GMT
Also if you can go stainless for both.
Alloy is a pain to weld diy and mild is just a short term fix...
As for "megaphones" just adjust the tube you are using with a meric adjuster ..
Any more Q's just shout up and post pics...
Jesus loves pics....................
Edit...
90% of F1 stuff is now 3D printed.....
Last Edit: Mar 16, 2017 22:33:43 GMT by usedabused
