Mar 20, 2017 10:19:26 GMT
Cylinder tank plus front end kit for a classic range rover fuel injected v8. Removed from a working vehicle and orignally destined for my RR, but sold it last year. Will also include a reel of new hose.
will get pics later
£99 collection from warwick
i'll get pics after work today :-)
What make is the kit? What sort/size tank?
Koos
Heres the cylinder tank, its 80litres
What make is the kit? What sort/size tank? Sorry for the delay in getting the pics. Its a lovato system. All labelled as it came off a working 89 3.9 efi. Was to go on my 90 vogue.
New reel of Faro pipework and hose ends are worth about £30 on their own.
Is that a lambda controller? Are there lambdas with it? Do you know the vaporiser model and diameter of the gas ring?
Koos
Is that a lambda controller? Are there lambdas with it? Do you know the vaporiser model and diameter of the gas ring? its single point open loop for non-cat engines, so no lambda's. the gas ring ID is 40mm which is the standard size to fit on the RR v8 plenum/throttle body as the v8 plenum lip is 65mm The vapourizer is probably this one but i'll need to check tonight www.lovatogas.com/php/eng/lpg_systems_detail/id_7_prodotto_m200.html as itsa for carb and non-cat efi engines
Nov 28, 2017 15:48:46 GMT
last bump before the tank gets weighed in
SOLDChasR
@chasr
Club Retro Rides Member 170
Is that a lambda controller? Are there lambdas with it? Do you know the vaporiser model and diameter of the gas ring? On a mixer system there is not much to be gained with Lambda control. Even on fully sequential systems there isn't ; There is no substitute for a bad setup . Once you know how to setup the various systems they are not too bad . A bump for a cheap LPG kit.
Last Edit: Nov 30, 2017 8:30:41 GMT by ChasR
Is that a lambda controller? Are there lambdas with it? Do you know the vaporiser model and diameter of the gas ring? On a mixer system there is not much to be gained with Lambda control. Even on fully sequential systems there isn't ; There is no substitute for a bad setup . Once you know how to setup the various systems they are not too bad . A bump for a cheap LPG kit. Rubbish!
Last Edit: Dec 1, 2017 9:48:26 GMT by mdh
Koos
SOLDChasR
@chasr
I guess fitting many trouble-free installations and fixing many 'experts' systems (including big names like Landi-Renzo) means sod all then .
Ditto! 😜 Expert systems are usually the worst imho!
Last Edit: Dec 2, 2017 12:07:21 GMT by mdh
Koos
