This is my old compressor, that I no longer use, and it`s just taking up space. It`s sort of spares/repairs I guess. It needs a pressure switch, as it has a constant leak when full. This doesn`t stop you using it, just makes an annoying hiss all the time, and means it fills up more often if using a lot. Also, it`s recently started tripping the electric when it reaches about 50 PSI. I`m pretty certain this is down to the electric wire being squashed under the compressor leg for a while, and it feels a bit.....flat! No doubt could do with a service too as I`ve had it about 3 years, and it`s never been done. Not been used in about 6 months though, apart from sporadically turning it on.
Anyway, here are pictures. It`ll need to be collected in a suitable car, or I`m happy to pallet it up and ship at cost.
