Thought I'd ask on here before going to Euro Car Parts or wherever to find parts.
I'm running my 1988 Sunny and having done one 5k oil change already with Castrol Magnatec, I figured it worth doing a more thorough service now I'm another 4.5k down the line.
Was thinking of the following list,
Oil change
Oil filter change
Air filter change
Coolant change
Top up of gearbox oil
Sparkplug check and replacement if needed
I would top up the power steering and brake fluid but check those regularly and neither need topping up.
Is there anything else I should consider at this stage? Does anyone have any recommendations other than what I can pick off the shelf at Euro Car Parts or similar?
There are other checks according to my Haynes bible - carb/fuel issues are being documented here: retrorides.proboards.com/thread/195582/carburettor-newbie - any in particular I need to focus on?
Disclosure: I have limited space to work on this, no garage and no access to more than socket set and basic tools. Have ramps, can get a jack and stands if need be. More than that is probably going to be a bit too much for me.
As ever - all help really appreciated.
Oil change
Oil filter change
Air filter change
Coolant change
