MiataMark
Club RR Member Number: 29
spinning bolt - helpMiataMark
@garra
Club Retro Rides Member 29
Fitting coil-overs to my MX-5, the bolt holding in the bottom of the shock absorber is just spinning . It goes into a threaded part of the lower wishbone that I can't access except with a finger. I can feel the bolt turning but it's not coming out. Any suggestions of how to remove it? Hopefully I can get out of this without having to get a new wishbone
Known issue. Been there, t-shirt, you know. From the underside, you can see the captive nut which became un-captive through a small slot. I welded the nut to the wishbone. Super-heroes do that with the wishbone in situ. MX5nutz recommend holding the captive nut with a spanner (17iirc), which leaves you with the problem getting the nut back in place for reassembly.
MiataMark
@garra
Thanks, don't suppose you have a picture from underneath do you?
Don't have access to a welder unfortunately and really don't want to drop the wishbone.
afraid no, I'm very bad at taking pictures when I'm working. But I foung this image, maybe it gives you an idea:
jonxs
Apr 10, 2017 11:04:38 GMT
You can get a slim spanner in the small opening on the base of the arm. Or a big screwdriver to wedge it over so you can crack the nut. That's how i managed it on my MX.
Apr 10, 2017 13:54:06 GMT
As above, get something, anything in there to lock the captive nut, when it's out you can fit a normal nut with a spanner through the the hole.
MiataMark
@garra
Apr 10, 2017 14:39:35 GMT
Thanks for all the help, it'll be a few days before I get a chance to look at it again, will update with progress.
Really really don't want to take the wishbone off, so I'll try and get the car higher so I can get a good look at try and jam something in there.
