Bought for the Cortina which is now long gone. Taking up space in the shed and could do with the money for an engine swap for the Polo.
Complete front Cortina subframe with upper and lower wishbones, uprights, brake discs, steering rack, the lot! Subframe has been stitch welded for added strength and rigidity.
Comes with a pair of GAZ coilovers and a bracket to attach the coilovers to the lower wishbone as well as high tensile bolts. Ideally to finish the set up the upper and lower mounts for the coilovers need to be strengthened with some 13mm ID tube.
The coilovers are Gaz (110/080 B12-2) Which add's upto 11" Open and 8" closed with a 12mm Rods
The springs you made need to change as they were set up for a cologne engined car. They're 2.25id 7" 500lb. Replacements are £15 each before vat
One poor photo:
Due to the size and weight collection only. Won't split at the moment.
Tom
One poor photo:
Tom
