Fiat cinquecento "s" one off 1.4 turbo pushing 232hp and is also AWD
Location; Telford West midlands
Price 6500GBP or nearest sensible offer, i did have a build thread on here but ive got to rehost all the pictures (photobucket aye) but if you look at the stuff i build nothing is skimped on as I'm going at speed
Engine
.2010 500 abarth tjet on 10,000 miles
.Tjet inlet with new bosch 625cc injectors
.1.6 cable throttle body with custom adaptor plate
.superlight TTV racing billet flywheel and CG motorsport unsprung 4 puk clutch
.new cambelt and aux belt and new alternator abit over a year
.custom 304 stainless log manifold and recon'd turbo technics custom T25 hybrid turbo
.mocal OTSB1 oil sandwich plate and ATS 13 row narrow oil cooler
.new custom braided water pipes hoses for turbo and oil cooler
. custom intercooler and silicone hoses
.MS2 ecu proffesionally installed and mapped by bailey performance has around 14 hours worth of mapping now, now has launch control and flat shift dialed in
.MSD gen 2 coilpack on custom bracket and 8mm silicone HT leads
.silicone coolant hoses
.last year had all engine mounts sand blasted and powdercoated then new bushes with poly inserts
.billet one off oil cap could do with a polish (just for dan)
running gear
.panda 4x4 gearbox
.panda rear diff mounted on custom setup uses oem bolt holes all sand blasted and painted then sealed
.4 custom sleeved driveshafts and shortened propshaft, all new cv joints and reinforced centre bearing
.new oem rear arms machined with custom billet hubs
.internal panda short shifter
.custom gearbox mount
.steering rack rebuilt last year
.new wheel bearings all around
brakes suspension
.punto GT3 brakes all around
.last year had all calipers recon'd with new discs pads
.new cunifer brake pipes and braided brakes pipes along with master cylinder
. TA technic coilovers front with new top struts and rear springs shocks with droop straps
.set of toko A539 tyres used for 1000 miles
. poly bushed engine mounts, arb, wishbone
.upper front strut braces
interior
.electric windows central locking
.various gauges in centre console for engine
.black dash interior and plastics
.carpeted b c pillars and wheel tubs
misc
.battery relocated in boolt with new wiring front to back
.50L foam filled fuel tank in boot
.complete torques uk fuel system, 044 external fuel pump with billet fuel filter and mountings
.black AN fittings on all fuel hoses both flexis and solid pipes front to rear
.custom alloy oil catch can with silicone hoses
.10mm spacers on the front and 16mm on the rear all hubcentrics
Its been around oulton park at tunerfest north(id lower the coilovers next time tho)
Been down pod numerous times, last was usc 2017 200 mile round trip and 9 runs down the strip without missing a beat, best was 13.1 @ 104 plenty of vids on youtube, also won the handing track.
Car is an absolute blast of the lights, ive timed 0-60 at 5.02 and theres abit more init to give
I've had the car touching near on 8 years now but ive got that many cars on the go now, I will of no doubt missed any small item, pictures are abit over a year old
I'm willing to do a deal at no extra cost to transfer it all over into a clean red shell i have supplied with 12 months mot and have the choice of keeping interior etc, daft i know but i just like my shell too much
Ash
Engine
running gear
.panda 4x4 gearbox
brakes suspension
interior
misc
Ash
