Aug 31, 2017 21:10:54 GMT
Came back to my car after work and small amount of water had leaked from somewhere near the rear drivers side wheel. Not the wheel but the actual car.
Doesn't smell of anything and no colour. Is this just water or is it something more sinister
Aug 31, 2017 21:48:02 GMT
Is it near the rear door, as it could be a bad seal behind the door card.
If water is in the rear footwell, this could be coming from the front, as the rear footwells tend to be the lowest point in the floor. On later B5 Audis, certainly pollen filter seals, made of foam, would break down, letting water past which would end up collecting in the rear footwells. I had this problem in my B5 VW Passat, and it was the pollen filter seal which I replaced with sealing cord.
Sept 1, 2017 10:14:16 GMT
Where can I find filter?
The pollen filter should be under the bonnet, almost tucked under the windscreen near the bulkhead.
