Shortcut
I won't be there when you cross the road, so always use the Green Cross Code.
That's the main reason I changed to alloy racing calipers with thin-walled pistons (although half the (unsprung) weight was good too). I assume that since I have Metro Turbo callipers, a set of alloy callipers for a Metro turbo would be an easy swap, rather than tracking down a different model of calliper that could be adapted to fit?
This space available to rent. Reach literally dozens of people. Cheap rates!
Would have expected them to be a straight swap but who knows where BL / Rover are concerned :-)
Shortcut
Aug 25, 2018 18:18:13 GMT
vulgalour
Club RR Member Number: 146
Not as bad as it could be, really, and the yellow wheels look great. Nice to see this one pop back up in my bookmarks after it disappeared for a bit.
Shortcut
Sept 9, 2018 15:33:24 GMT
And just like that it was entirely taken apart. It’s taken just over a year to get to the end of part 1 but that’s it. Every single part is now off the body. It’s just a (really quite rusty) shell. Hopefully the restorer people will pick it up next week. I suspect hey may be otherwise engaged with fancier cars. The weirdest thing was that despite its 37 years of age and barn living not a single bolt screw or nut was rusted up. Every single one came apart. One or two needed a squirt of WD but hats all. Freaky weird. Anyway here’s some celebratory pictures. Once the shells gone I can make a bench and start taking the actual parts apart.
Sept 9, 2018 16:56:11 GMT
They run Mac struts on all 4 corners? That's handy harry
Last Edit: Sept 9, 2018 16:56:21 GMT by darrenh
Shortcut
Sept 9, 2018 17:03:46 GMT
Yup. Way better handling than the 205.
Shortcut
Jun 12, 2019 10:24:24 GMT
Delayed update time... After a LOT of scraping and grinding, got the shell all tucked up into a panel van for a visit to the cleaners. A couple of weeks later and it's back!! and apparently a lot more of it is back than I expected. Rather than being mostly hole the shell turned out to look a lot better than it really should. Stripping company (who have done a bang up job applied etch primmer straight away as part of the process. So, back into the van and off to the body shop for some welding and a respray! With extra time on my hands I managed to use the cars dimensions to knock up some vector files for the stickers and decals for after the paint. The final effect should be somewhat like...
Last Edit: Jun 12, 2019 10:26:03 GMT by Shortcut
vulgalour
Jun 13, 2019 13:24:17 GMT
That's a bit of a result. Looks like all the rust repairs are going to be very small and localised, surprising just how good the rear floor and inner arches are.
Jun 13, 2019 13:29:22 GMT
I have tremendous memories of being thrown around the roads at night in one these (rally-road prepped) back in 89/90. It was night time (he had a pod of lights too which helped) and he absolutely drove it like the proverbial. I was v impressed with how it went (scared out of my wits!) Like the mock up and it's going to a cracker I'm sure.
big02
Jun 13, 2019 20:40:29 GMT
I saw this on the RJH faceache page, looks like a proper job.
Who is doing the body/paintwork if you don’t mind me asking? Is it reef?
Looking forward to the finished project.
Chris
Jun 13, 2019 21:31:45 GMT
This is so cool! Would like to see the progress. And the decals look awesome :-)
Shortcut
Jun 13, 2019 21:59:36 GMT
I saw this on the RJH faceache page, looks like a proper job. Who is doing the body/paintwork if you don’t mind me asking? Is it reef? Looking forward to the finished project. Chris No A1 Retro Sprays in Swindon are getting it on Tuesday. They specialise in older cars, Ford stuff mostly and seem to strike a good balance between proper resto joints (was quoted £15K by one place to finish the shell to final paint). The work Ive seen of theirs looks pretty good. I'm not after concours show stuff just a good solid job.
Last Edit: Jun 13, 2019 22:03:54 GMT by Shortcut
Shortcut
Jun 13, 2019 22:02:13 GMT
That's a bit of a result. Looks like all the rust repairs are going to be very small and localised, surprising just how good the rear floor and inner arches are. I know I was very happily surprised. A former keeper who had it for 15 years from almost new got in touch. He had kept it mostly in an underground garage while he had it, and while I had it it spent two years in a barn and then eight in a workshop in Ireland before I got it back, so it's spent more time under cover than not in its life which I think has helped a lot.
