v8ian
Nov 21, 2018 20:21:38 GMT
I was watching Combat Dealers on quest last night, there was a section about tracks for a Panther 1 tank, wasn't that something you were involved in? If so a man called Johnny with a suspicious accent appeared on the show to deliver the castings... Fascinating episode showing the factories in the Czech Republic. Suspicious accent maybe, but a very dodgy hat too
Nov 21, 2018 20:29:09 GMT
I was watching Combat Dealers on quest last night, there was a section about tracks for a Panther 1 tank, wasn't that something you were involved in? If so a man called Johnny with a suspicious accent appeared on the show to deliver the castings... Fascinating episode showing the factories in the Czech Republic. Suspicious accent maybe, but a very dodgy hat too It wasn't me. . . . . . ok. It was me . . , . . .but I wasn't aware if it 😂😂 Most people never believe me when I tell them that that accent comes from where I was born,Crowborough.....
Last Edit: Nov 21, 2018 20:44:11 GMT by Deleted
Tazzy
Nov 21, 2018 20:36:28 GMT
must.focus
Nov 21, 2018 20:40:15 GMT
I was watching Combat Dealers on quest last night, there was a section about tracks for a Panther 1 tank, wasn't that something you were involved in? If so a man called Johnny with a suspicious accent appeared on the show to deliver the castings... Fascinating episode showing the factories in the Czech Republic. That was me -3c early last December Was colder than a Witchestit....
Nov 21, 2018 20:51:19 GMT
Stupid busy at work again. Plenty early mornings and late nights. Haven't had time for anything else.managed to drill one hole in a bit of bar for the welding stool, that's all. 👎🏻 It does have its spin offs though, the first being a new tool box That's the first of two new investments. The second one is being built as we speak in Italy at considerable expense.... JB - I have the larger 96" version but mine is the 'Limited Edition' well used added workshop patina model Funnily enough Chris, I grew out of the 72" before I finished trying to pack my tools into it. Sold on for a profit last Friday. Bought a new 96" unit ,due to have been delivered today. Wasn't at the shop today,so will see it tomorrow. 96" much better layout with 5 rows of shallow drawers with one deep one at the bottom. 😊
Nov 21, 2018 20:56:09 GMT
Nov 21, 2018 21:19:10 GMT
Is that a foam mould? As in, its the core that melts away leaving the steel shaped?
Nov 21, 2018 22:04:22 GMT
Is that a foam mould? As in, its the core that melts away leaving the steel shaped? No. Its one of the patterns to make sand cores. We needed to cast 200 links. Cast two links at a time . Might see that in the Combat dealers episode,but haven't seen what they actually used ,footage wise 😊
Last Edit: Nov 21, 2018 22:09:24 GMT by Deleted
npp
Nov 21, 2018 22:09:49 GMT
Is that a foam mould? As in, its the core that melts away leaving the steel shaped? No. Its one of the patters to make sand cores. We needed to cast 200 links. Cast two links at a time . Might see that in the Combat dealers episode,but haven't seem what they actually used ,footage wise 😊 so how was that done industrially when they needed to make rather a lot of these things rather quickly?
MiataMark
Club RR Member Number: 29
Nov 21, 2018 22:17:55 GMT
Is that a foam mould? As in, its the core that melts away leaving the steel shaped? No. Its one of the patterns to make sand cores. We needed to cast 200 links. Cast two links at a time . Might see that in the Combat dealers episode,but haven't seen what they actually used ,footage wise 😊 The y just showed you breaking out the first two 'test' links from the mould, they also said they needed 172 links.
Nov 21, 2018 22:20:29 GMT
The patterns are reusable. They would have had a pattern to cast 4 at a time. They would have had more than one pattern. The patterns get reused over and over again to make the sand cores. The sandcores get filled with molten metal ,then destroyed to get the part out. With one pattern,with two impressions,we were able to make 16 links per day. That's without urgency,the will to work,let alone the will to live. It would have been easy to make double that with a two impression tool if our lives depended on it....
Nov 21, 2018 22:22:19 GMT
No. Its one of the patterns to make sand cores. We needed to cast 200 links. Cast two links at a time . Might see that in the Combat dealers episode,but haven't seen what they actually used ,footage wise 😊 The y just showed you breaking out the first two 'test' links from the mould, they also said they needed 172 links. That's tv for you, you need 94 per side on new sprockets..... plus either 6 or 8 spare that get fixed to the side. Like a spare wheel....
Last Edit: Nov 21, 2018 22:24:24 GMT by Deleted
Where do you work Mr. @johnnybravo my brother in law restores WW2 vehicles, tanks etc
Based down in East Sussex but do stuff for three tank restoration places in the Uk and one in Australia
Last Edit: Nov 22, 2018 9:04:21 GMT by Deleted
I looked up the episode of Combat Dealers for anyone interested, S04 E05 War Factories. Just after you say "I think I'll leave you to clean it up..." I can just about hear "...I've got an RX2 to build."
Last Edit: Nov 22, 2018 9:57:07 GMT by Deathrow
Nov 22, 2018 22:13:22 GMT
Company i work at now make the torsion bars for modern AFV’s.
npp
Nov 22, 2018 22:15:45 GMT
The patterns are reusable. They would have had a pattern to cast 4 at a time. They would have had more than one pattern. The patterns get reused over and over again to make the sand cores. The sandcores get filled with molten metal ,then destroyed to get the part out. With one pattern,with two impressions,we were able to make 16 links per day. That's without urgency,the will to work,let alone the will to live. It would have been easy to make double that with a two impression tool if our lives depended on it.... thanks for the explanation!
jamesd1972
Club RR Member Number: 40
Nov 23, 2018 10:41:08 GMT
JB - I have the larger 96" version but mine is the 'Limited Edition' well used added workshop patina model Funnily enough Chris, I saw that yours was bigger than mine, got a serious case of workbench envy so had to buy a bigger one to compete. FTFY James
glenanderson
Club RR Member Number: 64
Nov 23, 2018 11:42:55 GMT
I looked up the episode of Combat Dealers for anyone interested, S04 E05 War Factories. Just after you say "I think I'll leave you to clean it up..." I can just about hear "...I've got an RX2 to build." Watched that last night. Very interesting, but dear lord that Bruce fella is hard work. I’m still at a loss as to how much his Panther is worth... 😂
Frankenhealey
Club RR Member Number: 15
Nov 23, 2018 13:02:47 GMT
I looked up the episode of Combat Dealers for anyone interested, S04 E05 War Factories. Just after you say "I think I'll leave you to clean it up..." I can just about hear "...I've got an RX2 to build." Watched that last night. Very interesting, but dear lord that Bruce fella is hard work. I’m still at a loss as to how much his Panther is worth... 😂 I am recording it to watch at the weekend and if that @johnnybravo is not up to scratch then I'm asking for my money back!
